PANGEA AC 9SE MKII Power Cable C19 IEC Schuko OFC/Cardas Copper Triple Shielding 7AWG 2m
This C19 IEC power supply cable to Schuko integrates high-quality components with OFC and Cardas Grade One copper conductors and triple shielding.
Reference : 12408
249,17 €tax excl.
Available
Shipping date: 22-05-2019.
Orders placed before 1pm (GMT+1) will be shipped the same day (working day).
Pangea AC 9SE MKII
Power cable Schuko C19 IEC OFC Copper & Cardas Grade One Copper 2m
Pangea AC 9SE MKII
Specially designed for high currents
The Pangea AC-9 has been one of the bestsellers of the brand for many years. This AC 9SE MKII version is an improved version, allowing a boost of preformances. This will be ideal for power-hungry systems, such as a home cinema amplifier, amplified subwoofers, power amplifiers...
In spite of its name, the AC 9SE MKII is not a 9AWG cable but a 7AWG cable, thus including larger conductors, notably allowing a marked improvement in bass.
The first version of the AC-9 would incorporate 99.99% pure OFC copper conductors. This AC 9SE MKII version goes further by combining both OFC Copper and Grade One Cardas Copper, developed by George Cardas for the design of his own high end cables.
This copper is extracted in Arizona and shipped to a factory in England where it is slowly processed and worked to obtain, according to George Cardas,"the best copper on the planet, delivering incredible audio results.
The combination of this refined copper and high purity OFC copper results in an impressively efficient audiophile cable at a low price. Ideal for taking your audio system to another level.
Maximum noise rejection
The AC-9SE MKII therefore incorporates high quality conductors to ensure optimum conductivity. In addition, the use of 7AWG conductors allows high currents to be routed without any problems and its specific design allows for optimised AC power supply in 50/60Hz.
The spiral conductors greatly reduce noise, and the double shielding of the cable ensures noise reduction for high currents.
On the connector side, their design protects them from oxidation and corrosion to extend their service life.
DeathGrip™ IEC
Very often, the weak point in the power supply circuit corresponds to the IEC connector. Here, Pangea selects DeathGrip connectors with wide gold-plated contacts and a robust attachment system.
Technical Characteristics
Cable length2m
IEC20-Amp C19 IEC DeathGrip with large gold plated contacts
Ideal for high currents-
Conductors materials99.99% pure OFC Copper, Cardas Grade One Copper and Litz Wire
Conductors insulationPE
Contacts plating24k Gold
Conductors section7AWG
ShieldTriple shielding with Aluminium Foil and Braided Silver Plated OFC Copper.
sheathPVC + Nylon
Connectors bodyMolded connectors, high robustness
MaterialCopper
Max length2m
PlatingGold
Separated conductorsYes
Insulation materialPE
Insulation materialPVC
ShieldingYes
ConnecticMale
Section (mm²)10.5
ConnectorC19
ConnectorSchuko
Colissimo - TNT - SoColissimo
