câble monstrueux par le diamètre mais surtout
pour le son .Une merveille. Un rapport qualité prix
incroyable .
By buying this product you get 22 loyalty points
Power Cable Triple Shielded OFC Cardas Copper 3x10.5mm² 1.5m
The power supply cable Pangea Audio AC-9SE MKII has been specifically designed to provide the power required for high power mono or stereo amplifiers. It is also ideal for amplified subwoofers and is an excellent choice for use with demanding high voltage line conditioners.
Its combination of superior quality materials, advanced design and shielding improve the performance of connected components.
The new AC-9SE MKII is equipped with a gilded conductor pair Cuivre OFC and Cuivre Cardas Grade One, specially developed by George Cardas for his own cables. This sector cable also has triple OFC Copper braided Silver plated shielding.
Due to their high current requirements, power amplifiers must have larger conductor sizes than standard power supply cables generally offer. The Pangea AC-9SE MKII is the perfect answer to this constraint.
Product type | Power cable |
Connectors | 1x Schuko 1x IEC C13 |
Length | 1.5m |
Cable conductors | OFC Copper Cardas Copper |
Section | 3x10.55mm² (7AWG) |
Triple shielding | Braided Silver plated OFC Copper |
Connectors contacts | 24k Gold plated OFC Copper |
Cable diameter | Ø23mm |
Weight | 1660g |
Cable color | Black, gray and blue |
Length (m) | 1.5 |
Shielding | Yes |
Section (mm²) | 10.50 |
Connector | Schuko |
Connector | IEC C13 |
Conductors material (Cable) | Copper |
Conductors Plating (Cable) | None |
Average votes 5.0 / 5 1 reviews | Why write products reviews ? You can share your feelings about products and help other people by sharing your experience |
