By buying this product you get 39 loyalty points
Power distributor 6 ports Aluminum FURUTECH Black
The Audiophonics MPC6 V2 CLC represents the new generation of high-end power sockets / filters. With a revised and corrected finish with rounded nails, a better mechanical resistance of the whole, the Audiophonics MPC6 V2 allows great possibilities of sector optimization.
This new generation MPC6 V2 CLC includes a new aluminium finish with rounded corners with a better finish and increased electromechanical performance.
This Audiophonics MPC6 V2 mains distributor contains a PI filter (CLC) allowing the attenuation of harmonics derived from the 50Hz polluting the musical signal. This elegant solution allows a high efficiency in terms of results without damaging the dynamics of the sound message. The components for this mounting allow a maximum current of 16A.
The advantages of the PI CLC filter are many:
Throughout the process of creating this product, the emphasis has been placed on the choice of materials in order to obtain one of the best possible mains interconnections.
The connectors are entirely from Furutech sources and treated with the famous Alpha process, the ELECAUDIO wiring wire has been selected for its monocrystalline OCC copper, PTFE insulation and very low impedance. The retained tips allow a better contact and an increased protection against corrosion, the aluminium case has been selected for its solidity, inertia and robustness.
Here are the IEC, Schuko, and wiring sockets used for the Audiophonics MPC6 V2:
Schuko Connector :
IEC Connector :
Câblage :
Specifications | ||
Product type | Power distributor | |
Number of Schuko plug | x6 Gold Plated Pure Copper Schuko FI-E30 | |
IEC Plug | Furutech FI-06 | |
Anti-slip rubber feet | Yes | |
Housing panels thickness | Front/Back panels: 3.5mm Side panels: 3.5mm Top panel: 8mm Bottom panel: 3mm | |
Dimensions | 340 x 123 x 75mm | |
Weight | 2.34kg | |
Color | Black |
