FURUTECH AC-1001 (G) IEC Base C13 Gold Plated EMI Filter 230V 10A
Reference : 11142
39,90 €tax incl.
33,25 € tax excl.
Shipping from France
Billing in France
Technical support in France
This baseIEC FURUTECH AC-1001 industrywith non-magnetic treatment Alpha responds to problems related to pollution sector with the processes that have made the success of the Japanese brand. The nylon and fiberglass body (Piezo Epoxy), andgold-plated connectorsguarantee internal immunity, a significant reduction in parasitic noise,strong>electromagnetic interference EMI and EFI .
This filter is most effective for filtering disturbances when the capacitors prove insufficient. An excellent choice to transform the sound of a CD player, a DAC and devices with low current consumption like preamplifiers for example.
This FURUTECH IEC filter will be especially effective in hostile environments surrounded by bad quality AC adapters rejecting the harmful sector pollution for audio fidelity: (internet box, games console, smartphone 5V USB, house lighting).
The result is immediately identifiable with a limpid sound, a calm, a better rendering of the higher harmonics.
This filter is imperative to be connected to ground to operate at its highest potential.
This socket is compatible with the lugsFURUTECH FT-210.
Specifications:
  • Type: IEC C13
  • Outputs on gold plated lugs with cryogenic processing Alpha
  • IEC Plated Gold Pin with Cryogenic Processing Alpha
  • Internal Fiberglass Body, Zinc Epoxy and Nylon
  • Metal outer body
  • Two pines plus ground
  • Operating Voltage: 115V / 250V Max 50 / 60Hz
  • Current 10A
  • Contains a filter with two chokes of 0.2mH, a capacitor of 0.1μF and two of 2200pF
Dimensions and weight:
  • Dimensions: 57x28x20.8mm
  • Weight: 40g
MaterialCopper
Mounting typeTo screw
ConnecticMale
ConnectorIEC C20
