EMI / RFI Main Power Filter 230V 10A with Cables
EMI noise filter 230V 3A with cable
This high-performance mains filter is designed to filter out disturbances when capacitors are insufficient. It meets strict construction standards. Single-phase male IEC model, this filter accepts a maximum voltage of 250V at the input and operating currents of up to 10A.
4.5 / 5
Reference : 11628
5,90 €tax incl.
4,92 € tax excl.
Shipping date: 24-04-2024.
Shipping from France
Billing in France
Technical support in France
Main Power Filter
Filtre Secteur EMI / RFI 230V 10A avec Câbles
This high-performance mains filter is designed to filter out disturbances when capacitors are insufficient. It meets strict construction standards. Single-phase male IEC model, this filter accepts a maximum voltage of 250V at the input and operating currents of up to 10A. Its effectiveness is formidable against electromagnetic disturbances (EMI) propagated by radiation or conduction. Equipped with incoming and outgoing wires, it will be easy to use for repair or for a quick and efficient installation.
Product typeMain power filter
Operating voltageMax. 250V 50/60Hz
Operating currentMax. 10A
Average cable length13cm
Cable section0.823mm² (18AWG)
Operating temperature range-25°C to +85°C
ComponentsSelf 2X1.8MH,Capacitors 1X0.1µF 3300pF
CertificationsUL 1283
CSA 22.2
IEC/EN 60939
Included Fuse3.15A 250V
Weight40g
Dimensions42 x 32 x 21mm
Fixation holes spacing41mm
Rated current (A)10.0
8 reviews
Efficacité impressionnante
J'ai acheté ce filtre pour l'installer sur le câble d'alimentation de mes enceintes PC et le résultat est là. Mes enceintes étaient tout simplement inutilisables car les parasites couvraient le moindre son qui aurait pu en sortir, après installation de ce filtre je n'entends des parasites qu'à volume très très faible et il faut tendre l'oreille.
Allez y les yeux fermés surtout pour ce prix là !!
This review has been posted for EMI / RFI Main Power Filter 230V 10A with Cables
A worthwhile upgrade for the money!
Pas ébouriffant
J'ai choisi d'acheter ce produit pour ne pas entendre le démarrage de mon frigo sur mes enceintes, entre autres parasites... Et j'entends toujours mon frigo démarrer ainsi que le reste des autres parasites. Peut être qu'il bloque les parasites que je n'entends pas ?
Donc déçu, mais pas non plus outré à ce prix là.
En revanche, il faut noter que le boîtier est scellé, ce qui n'est franchement pas terrible en termes de durabilité en 2021.
Donc inutile + non modifiable = pas la peine d'acheter.
très efficace
Je suis très étonné par l'efficacité de petit filtre secteur qui se défend plus que bien.
Sur le plan sonore, en Hifi on gagne nettement en silence et fluidité
En bref: super rapport qualité/prix.
A recommander chaudement !
Ce que je cherchais.
Ce filtre répond bien à ce que je désirais,
Pour l'alimentation secteur d'un ampli, tuner ou autre.
This high-performance mains filter is designed to filter out disturbances when capacitors are insufficient. It meets strict construction standards....
