AUDIOPHONICS MPC6 V2 CLC Power distributor 6 ports Aluminum FURUTECH Black
By buying this product you get 39 loyalty points
Reference : 11706
399,00 €tax incl.
332,50 € tax excl.
Available
Shipping date: 20-06-2018.
Orders placed before 1pm (GMT+1) will be shipped the same day (working day).
Accessories
The Audiophonics MPC6 V2 CLC represents the new generation of power strips / filters. The Audiophonics MPC6 V2, with a revised and corrected finish with rounded fingernails and improved mechanical strength, offers great possibilities for optimization.
This new generation MPC6 V2 CLC includes a new aluminum finish with rounded corners with better finish and increased electromechanical performance.
This sector distributorAudiophonics MPC6 V2contains a PI filter (CLC) allowing attenuation of harmonics derived from the 50Hz polluting the musical signal. This elegant solution allows a high efficiency in terms of result without harming the dynamics of the sound message. The components for thisto support a maximum current of 16A.
Advantagesof the PI CLC filterare many :
  • Reduction of electromagnetic pulses (EMI) and interference on radio frequencies.
  • Protections against transient overvoltages (varistors Metal Oxide (MOV) (max current supported: 6.5Ka).
  • Immunity to external noise and reductions in emissions to the mains.
Throughout the process of creating this product the emphasis has been placed on the choice of materials so as to obtain one of the best possible interconnections sector.
Thea connectic is integratedsourceFURUTECHand processed with the famous Alpha process, the ELECAUDIO wire has been retained for its monocrystalline OCC copper, its PTFE insulation and its very low impedance. The retained tips allow better contact and increased protection against corrosion,ttp: //www.audiophonics.com/en/boitiers-aluminium-c-6276.html "target =" _ blank ">aluminum housinghas been selected for its massiveness, inertia and robustness.
Here are the IEC, Schuko, and wiring jacks used for the Audiophonics MPC6 V2:
Sockets Schuko:
IEC socket:
Wiring:
Chassis thickness :
  • Facades: 3.5 mm
  • Sides: 3.5 mm
  • Top: 8mm
  • Bottom: 3 mm
Characteristics :
  • 6 plugs Schuko FI-E30 Pure gold plated copper
  • IEC FURUTECH FI-06 connector
  • Anti-slip rubber feet
  • Dimensions (in mm): 340 x 123 x 75 (W x W x H)
  • Weight: 2.34kg
  • Black color
distributor MPC6 V2 available in several colors
___________________________________________
Audiophonics mpc6 v2 "src =" http://www.audiophonics.com/img/cms/IMG_1827-detoure-1000-de-largeur.jpg "alt =" Audiophonics mpc6 v2 distributor "width =" 700 "height =" 368 "/>
DIY MPC6 V2 housings available in several colors
distributeur Audiophonics mpc6 v2
MaterialAluminium
ColorNoir
PlatingGold-plated
StructureAluminium
Colissimo - TNT - SoColissimo
