FURUTECH e-TP309E Sector filtre 4 port Carbon
FURUTECH e-TP309E NCF Filtre secteur 4 ports
By buying this product you get 1089 loyalty points
Reference : 11334
3 635,00 €tax incl.
3 029,17 € tax excl.
Shipping from France
Billing in France
Technical support in France
The FURUTECH e-TP309 sector distributor, luxurious and sophisticated, of the highest level in aluminum is the element that completes the mains network of your Hifi High End chain.
An essential element, this AC outlet decoupled from the ground by anti-static nano-carbon tips will do justice to Furutech brand cables and connectors.
furutech GC-303Its film-coated filmGC-303 Technologyon the lower carbon part immunizes this mains plug of the EMI waves generated in the housing.
Piezo Effect Treatmentceramic and RFI radio shielding:
The Furutech Piezo Effect transmission system is an innovative technique. This special material is a combination of ceramic nanoscale particles and powdered carbon embedded in a nylon and fiberglass body.
the resultant Piezo Effect on the body of this aluminum AC outlet is a generation of electric charge forming a mechanical and electrical bridge.
The result is non-stop offering an inert anti-resonant and mechanically decoupled body. TheThe upper part of this mains distribution block is made of anti-vibration carbon. To mechanically perfect this anti-vibration effect, the Schuko plugs have a vibratory flow system for axial fixing that eliminates the resonance by a factor of 10.
Furutech Fi 09 R
Pure copper conductors and Alpha treatment:
Furutech Fi 09 RAn electrical outlet must have the best quality of electrical contact. The Furutech IEC Furutech FI-09 R input connector of this Furutech mains plug is made of pure copper treated and Rhodium Alpha plated. The Alpha process takes place in the first part by a cryogenic treatment of copper at a temperature of from -196 ° to -250 °.
Thethe copper pellets after this shock treatment tighten and behave more stably ensuring better electrical transfer. The second part of the treatment comprises a long demagnetization process with a magnetic ring specific to the Japanese mark.
Internal wiring and very high level connectivity:
The original Furutech original star wiringcopper (FT-D15A R and FT-S15A R) fully treated Alpha (non-magnetic Rhodium) provides low linear resistance in a separate resonance-absorbing space. The non-magnetic Schuko Phosphor Bronze shafts treated with Rhodium ensure a high contact stability over time. Their insulating composition is made of nylon and fiberglass of Piezo Effect type anti-static.
NCF technology:
furutech NCFIncorporated in the new series of Furutech products, the NCF (Nano Crystal² Formula) consists of a special crystalline material that has two "active" properties.
TFirst, it generates negative ions that eliminate static electricity, but it also converts thermal energy into far infrared (LIR) whose wavelength varies from (50 μm to 5 mm).
Furutech then combines this remarkable material with nanoscale ceramic particles and carbon powder for their "Piezo Effect" (damping properties).
The resulting Nano Crystal² (NCF) formula is the ultimate electric and mechanical damping material - (only available in Furutech products!).
Characteristics:
  • Supply voltage: 250V 50 / 60Hz
  • Supported Current: 15A
  • Maximum power. 2500 W
  • 4 bases SHUCKO Furutech plated Rhodium
  • Anti-vibration treatment
  • Dimensions: 297 X131 x70mm including the feet
  • Weight: 3.4lbs
Number of sockets4
FilteringYes
