ifi Audio DC iPurifier 2 Filter AC Adapter 5V-24V / 3.5A / 84W
ifi Audio DC iPurifier 2 Filtre Adaptateur secteur
Removes the noise naturally present in the general electrical circuit to eliminate a large part of the avoidable audible errors in the final sound reproduction. Compatible with any electronic device powered by SMPS.
4.2 / 5
Reference : 13035
119,00 €tax incl.
99,17 € tax excl.
Last items in stock !
Shipping date: 19-03-2024.
Shipping from France
Billing in France
Technical support in France
iFi Audio DC iPurifier2
active noise suppressor for switching power supply (SMPS)
iPurifier II by iFi Audio, audio filter DC converter SMPS
This accessory is placed between an electronic device and a DC adapter. Its role is to clean the sound naturally present in the overall electrical system to eliminate much of the audible preventable errors in the final sound reproduction. It can be mounted on any type of electronic device powered by SMPS in the string, be it a digital player, DAC or an amplifier. All equipment and all the elements that follow will benefit from a more defined signal. A great improvement for reducing the noise and gain precision in order to highlight the qualities of an audio system.
iFi Audio iPurifier active noise suppression filter
Second generation of noise canceling iFi Audio
This is the second version of iPurifier by iFi Audio. This second model further refines the machine's hardware capabilities to offer ever more effective removal of unwanted noise.
Its function is to smooth and filter the sound artifacts generated by the modulation of pulse length produced by switching power supplies. It is expected to apply a reduction factor of 316 times to 100 000 times. This core application induces a significant improvement in his at all levels of the chain using a SMPS (Switch). Whether naturally a critical element that DAC, a digital / CD / network or amplifier,
As with its first generation, the design incorporates iPurifier ANC technology (Supression active noise), directly inspired by the radar technology - especially the Spectra system of Thales.
Precision electronic components
noise suppression noise gate audio high fidelity set ifi
To operate a specific filtering supply noise, the iPurifier operates a wide range of electronic components of high quality and carefully selected for this application:
there are capacitors Panasonic SP-Cap Polymer Aluminum, high-precision MELF resistors, custom AOP high-speed / ultra-low noise.
There is also a shield designed from a copper alloy developed to block the best Electromagnetic interference specific for this use.
The housing itself is designed in a shielded alumunium aircraft grade so that the signal does not recapte new interference once filtered.
Active filtering precision
active filter the noise smps
Removal is made possible by the identification of noise and applying a reverse phase signal.
If iPurifier filter any unwanted frequencies over a wide band 1Hz - 5GHZ, the deletion is of course centered on 20Hz-20Khz band to purify as much as possible the audible frequencies and improve the sound quality on all power supply devices SMPS.
electrical performance
Beach tolerated tensions5-24VDC
Up to 84W / 3.5A
Constructionaluminum frame RFI shielded aeronautical grade
Parts suppliedAdapter 5.5 x 2.1 mm
Adapter 5.5 x 2.5 mm
Adapter 3.5 x 3.5 x 1.35 mm
Number of sockets1
FilteringYes
6 reviews
surprenant et efficace
monté sur une boc upc et un modem wifi upc. j ai gardé les alim a découpage d origine car les remplacer aurais couté cher. Deux de ses petit purifier ont eu d excellent résultats .image plus dynamique précise et le bruit a bc reculé. Le son que je récupère sur un bloc HDMI extracteur audio a gagner en précision dynamique et clarté, grave plus propre et ample.. l autre monté sur le modem a apporté les mêmes résultats avec une bande passante plus large vus les améliorations d écoute sur mon streamer.. pour le prix sais du bon rqp. conseillé vivement avant l achet d alimentations dédiées .
This review has been posted for ifi Audio DC iPurifier 2 Filter AC Adapter 5V-24V / 3.5A / 84W
Must have
Try with my NUC Streamer .Superior performance than linear AMP
Better bass response,detail and silence.
Ready to order another one for my Project Audio CD Trasport to work together with Ifi IPower
Inutile ?
Sur mon système, pas entendu de différence d'aucune sorte avec ou sans le IFI DC purifier. Essai sur SMSL DP1 (démat) sortie optique sur convertisseur CD Cairn fog3 modifié, ampli tube Kalipso baffles plan supravox + ligne acoustique supravox pour extrème grave (la cave aux tubes). Très inférieur à la lecture cd par ailleurs.
propreté du courant
Bonjour ,ifi 2 sur mon phono mk2 rega , amelioration de la precision et clarté ,basse plus serré , petite perte d ampleur et de matiere , sur mon decodeur canal ,l image a gagné en tout et le son de ma barre idem ,bon produit dans l ensemble .
article très complet
branché à un switch ethernet Silent Angel Bonn N8 écoute améliorée de Qobuz ou Tidal
Je recommande ce fournisseur très aimable et à l'écoute
Removes the noise naturally present in the general electrical circuit to eliminate a large part of the avoidable audible errors in the final sound...
