IFI AUDIO IPURIFIER 3 EMI Filter Female USB-B 3.0 to Male USB-B
In order to drastically reduce the noise of your system, iFi Audio offers you the iPurifier 3. This will reduce distortion effects to finally find the details of your music.
4.7 / 5
Reference : 13122
149,00 €tax incl.
124,17 € tax excl.
Shipping date: 23-04-2024.
Shipping from France
Billing in France
Technical support in France
iFi Audio iPurifier 3
Filtre EMI USB-B 3.0 Femelle vers USB-B Mâle
iFi Audio iPurifier 3 Filtre EMI USB-B 3.0 Femelle vers USB-B Mâle
In this version the iPurifier has been greatly improved. It is based on 3 technologies to improve the restitution of your system: REclock, REgenerate, REbalance. It also uses Active Noise Cancellation technology to suppress noise. In addition, the iPurifier 3 is compatible with PCM, DSD and DXD formats.
iFi audio iPurifier 3 active Noise Cancellation
For its iPurifier 3, iFi Audio is based on Active Noise Cancellation technology, adapted from military defense radars. This allows the noise frequencies to be identified and then identical but opposite frequencies to be generated in order to cancel the noise.
Re-clocking 3-in-1
The iPurifier also incorporates other technologies to purify the audio signal. Thus, with REclock the device provides an accurate clock and regenerates the signal to eliminate the jitter. REbalance technology allows the DC offset to be removed from the USB signal to rebalance it. This reduces the overall noise on the input signal by 40dB.
iFi Audio iPurifier reclock
ifi audio iPurifier 3 composants
Components of exceptional quality
To achieve such performance, the iFi Audio iPurifier 3 takes advantage of high quality components. OS-CON capacitors are found there. These have low ESR with excellent noise reduction capabilities, ideal frequencies and long service life. Highly stable polarized Tantalum capacitors are also integrated, as well as very accurate and reliable MELF resistors.
Anti-EMI Shielding
To block EMI interference that could affect the sound reproduction of your system, the iPurifier 3 uses a copper alloy shield to insulate cables and devices.
iFi Audio iPurifier 3 Blindage EMI
Tip: For optimal results, it is recommended to pair this iFi Audio iPurifier 3 with a câcable USB iFi Audio Gemini and a power supply iFi Audio iPower.
InputFemale USB-B
OutputMale USB-B
TechnologyActive Noise Cancellation (ANC)
REclock/REbalance/REgenerate
Dimensions64 x 19 x 20mm
Weight33g
ColorWhite
Package1x iFi Audio iPurifier 3
1x Female USB-B to male Micro USB mâle adapter
1x Female USB-B to male USB-C adapter
1x Female USB-B to female USB-A adapter
OutputUSB
Max sampling rateNC
ColorWhite
Output voltage (V)NC
Output current (A)NC
Input voltage (V)N/A
Power SupplyPower supply filter
Interface chipNC
6 reviews
Accessoire dispensable
Si le produit est bien construit et livré avec divers adaptateurs qui peuvent être utiles, son insertion à l'entrée USB de mon ancien DAC n'a pas apporté de modification clairement audible sur mon système que ce soit en bien ou en mal.
Je ne l'utilise plus avec mon nouveau DAC.
Je reste dubitatif sur son utilité réelle.
Laurent G.
This review has been posted for IFI AUDIO IPURIFIER 3 EMI Filter Female USB-B 3.0 to Male USB-B
Un gain évident en transparence
Ce iPurifier vient s'ajouter au iSilencer 3 au sein de mon système (liaison entre un Zen Stream et un DAC Topping D70s).
Après quelques heures d'écoute, il m'apparaît que cet appareil finit d'exhumer les quelques détails supplémentaires que mon système est capable de reproduire.
Un peu plus de résolution, oui, mais surtout, ce qui est le plus net pour moi, c'est l'amélioration des timbres des cuivres, sur toutes les oeuvres que je connais déjà très bien.
Je dirais sans être formel que le iPurifier est allé chercher quelques harmoniques dans les hautes fréquences.
J'ai également des attaques et extinctions de notes plus perceptibles, notamment sur les violons et les pianos, la musique devenant plus riche et plus expressive.
Le bas médium/haut grave paraît également plus propre, plus dégraissé, certaines voix semblent de ce fait plus faciles à détacher des instruments jouant en simultané.
Encore autre chose, un peu plus d'aération entre les instruments et plus de douceur globale
En somme, ce petit gadget ne me déçoit pas et parvient avec succès poursuivre l'optimisation d'un système déjà tout à fait superbe...sachant que j'écoute au casque et que le gain est sûrement plus net encore aux enceintes
Works really well even with other USB cleaning and rec locking devices are used.
phénoménal !
j’avais acheté dernièrement le isilencer 3,0 de la mème marque. Cela apportait tellement à mon audio GD NFB 29H que j’ai voulu essayer la version plus évoluée du système de chez IFI.
Bien m’en a pris, c’est époustouflant ! La mauvaise nouvelle, c’est que c’est encore mieux en utilisant le isencer 3,0 en sortie de PC et le Ipurifier 3 en entrée du DAC. C’est mieux mais c’est plus cher...Mais l’investissement est vraiment pertinent. Timbres , dynamique, rythme, harmoniques, réverbes, profondeur, etc, on gagne sur tous les plans. Cher mais finalement par rapport au résultat, c’est un excellent investissement.
 (3)
Spectaculaire
J'avais déjà été largement convaincu par les 2 ifi Audio AC iPurifier Filtre secteur actif que j'ai installé sur mon bloc secteur et j'ai largement commenté les effets bénéfiques sur le son.
En installant ce filtre à l'entrée de mon dac AUDIOPHONICS DAC AK4495SEQ la qualité a encore fait un bon en avant.
Là tu te dis que l'ordi génère un paquet de m.....
Inouï comme le son est encore plus pur, les voix ont encore gagné en filé et transparence, les basses sont plus fermes et on gagne en spatialisation .
L'effet est encore plus flagrant que les filtres secteur .
AMPLI LINE MAGNETIC LM-211IA - Tubes PSVANE 6CA7-TII MARK II - DAC AUDIOPHONICS AK4495SEQ upgradé avec AOP SPARKOS LABS SS3602 - Enceintes Tannoy xt8f - Cables Audiophonics. Streaming Qobuz HI-RES studio via AUDIRVANA
In order to drastically reduce the noise of your system, iFi Audio offers you the iPurifier 3. This will reduce distortion effects to finally find...
