Switching power supply adjustable voltage 6-15V 5A
Alimentation à découpage voltage réglable 6-15V 5A
Reference : 2924
45,00 €tax incl.
37,50 € tax excl.
Available
Shipping date: 12-12-2018.
Orders placed before 1pm (GMT+1) will be shipped the same day (working day).
Switching power supply, 5 A, with switchable output voltage
Characteristics :
  • Ideal for peripherals such as printers, scanners, electronic notebooks
  • Short-circuit protection, overload and overheating
  • Connection cable 1,8 m
  • Polarity selection by reversing the supplied adapters
  • 7 adapters: 2.5 mm jack plug, 3.5 mm, power plugs: 2.35 / 0.75 mm, 3.5 / 1.35 mm, 5.0 / 2.1 mm, 5.5 / 2 , 1 mm, 5.5 / 2.5 mm
  • Compatible T-AMP: 13.5V - 3.8A
  • Caution: check the polarity when connecting the end caps
High power for small dimensions and low weight.
Current values ​​vary depending on the selected output voltage. Refer to the table.
Input Voltage 100-240 V~ / 50-60 Hz / 60 VA
Output voltage 6 / 7,5/ 9/12 / 13.5 / 15 V direct current
Load / Output Current 5/5/5/5 / 3.8 / 3.8 A
Charging time -
Holding load -
Reactivity -
Operating temperature 0-40 ° C
dimensions 70 x 37 x 140 mm
Weight 480 g
Colissimo - TNT - SoColissimo
