FX-AUDIO PT2313 Volume / Tone Controler, Source Selector, Remote Control
4.4 / 5
Reference : 12147
14,90 €tax incl.
12,42 € tax excl.
Available
Shipping date: 25-09-2018.
Orders placed before 1pm (GMT+1) will be shipped the same day (working day).
Volume Control / Tone + Display + Buttons + Remote Control & IR Receiver + Rotary Encoder
This FX-Audio module incorporates a PT2313 audio processor from Princeton Technology Corp. This allows you to control the volume, bass, treble and balance for up to 3 different sources for your DIY amplifiers. In addition, the chip offers the Loudness functions and the choice of gain per source independently. It comes with a screen, an IR receiver, a remote control, a rotary encoder and a button panel. Once installed, it is an indispensable tool for simply controlling an amplifier module.
The second output is used to power a rear stereo output. The FADER function or balance don't work.
TECHNICAL CHARACTERISTICS
  • Chip: PT2313
  • Controls: Volume, Bass, Treble, Balance
  • Loudness functionality
  • Up to 3 inputs with independent volumes
  • Fader control and balance up to 4 speakersindependently
  • Input / Output for external Noise Reduction or EQ
  • Control of the volume in steps of 1.25dB
  • The pack contains: 1x PT2313 controller, 1x display, 1x IR receiver, 1x remote control, 1x button panel, 1x rotary encoder, 4x XHP 3 poles to bare wire.
FX-Audio processeur audio contrôle volume / tone
Colissimo - TNT - SoColissimo
7 reviews
Fonction mute
Bonsoir
il faut utiliser la sortie interface de contrôle, lorsque mute est affiché on retrouve 5v sur une des broches, et de la piloter des relais, comme la laisser entendre Manfred.
This review has been posted for FX-AUDIO PT2313 Volume / Tone Controler, Source Selector, Remote Control
BON RAPPORT QUALITE PRIX
Fonctionne bien
par contre je n'arrive pas à faire marcher la fonction mute elle s'affiche sur l'écran mais ne coupe pas l'audio, si quelqu'un a la solution!
un petit synoptique ne serait pas superflu
Module intéressant
Bonjour
Je compte l'utiliser pour concevoir un préampli sélecteur de sources.
les fonctions du module on était bien décrites par Joel P .
Je regrette l'absence de la fonction balance/fader .
Je n'ai pas encore pu tester la qualité de l'audio.
Merci à AUDIOPHONICS pour ces modules.
sympas a utiliser .a par le manque de doc.
Bonjour,
Nous pensons l'illustration de la fiche décrivant tous les connecteurs satisfaisante pour utiliser ce produit.
Module fonctionne et manque de doc
Bonjour,
Ce module fonctionne bien a par mes petites problème aux déballage. Comme d'habitude aucune doc disponible c'est dommage.
Le fameux potentiomètre dernier l’écran et pour régler le contraste de l'écran.
Les fonctions on/off et mute sont non fonctionnelle a première vu! Faux, c'est sont commander par un connecteur J8 ( sortie d'interface de contrôle) c'est pour commandé des relais de 5volt, cela serait bien de la part de AUDIOPHONICS de nous sortir un module supplémentait pour le FX-AUDIO.
Je confirme aussi que la fonction Contrôle fader et balance ne fonctionne pas.
A noter que le codeur rotatif est moyennement bien géré, et qu'il peut se produire des sauts imprévus lors du réglage des graves/aigus par exemple.
Merci à AUDIOPHONICS de nous sortir un module supplémentait pour le FX-AUDIO et de la doc.
