TSA1020 Volume control module Source Selector RCA
TSA1020 Digital Audio Volume Controller - RCA
4.0 / 5
Reference : 12870
15,90 €tax incl.
13,25 € tax excl.
Shipping date: 26-04-2024.
Shipping from France
Billing in France
Technical support in France
VOLUME CONTROLLER TSA1020
digital volume controller / source selector compatible with Bluetooth receiver Audio B Plus
digital volume control with digital encoder & eacute; America and bluetooth link
This unit is a volume controller with RCA input and exit. It also loads a BVC output to control the volume of a module Audio B Plus (Bluetooth receptor for power amps). With its single knob, the TSA1020 ensures the source selector functions, standalone stereo volume control and digital volume control for Audio B Plus.
entrance control volume and RCA
Can be used as a stand alone unit
In traditional volume control Mode TSA1020 connects easily to your sound system with a RCA input and an RCA stereo output. The connectors are already soldered on the board and are ready for use.
Power is working with a female jack plug 5.5 / 2.1 already installed and ready for use. We can therefore very easily use this module as a movable element of the chain (stand-alone with its own housing) as well as connect internally to other equipment in order to increase the functional field.
Control Audio B More
Bluetooth TSA1020
The BVC TSA1020 has a port for connection to a Bluetooth receiver Audio B plus. Typically, these modules are designed to be attached directly to the amplifier.
When used with a compatible amplifier Audio B Plus, it TSA1020 Module greatly facilitate navigation between different audio sources (wired or not) while keeping the centralized volume control around a single rotary knob.
PinDirectionDescription
5V-
GND-
INCDigital OutputBluetooth Volume Audio +
DECDigital OutputBluetooth Volume Audio -
SELDigital InputSélection Bluetooth/Single-ended
1-Bluetooth,
0-Single-ended
Use as stand-alone volume controller
volume control RCA plug
Use as an external volume control for Bluetooth receiver module Audio B plus
control volume for audio over Bluetooth b
Use as a volume controller and source selector
Audio source selector TinySine B plus RCA
The module does not offer source selection. The volume control is therefore only done on the Bluetooth or on the line input, but not both at the same time.
Dimensions81x38mm
External KnobVolume Control
Power SupplyDC8V-38V
distances↔ 71.8mm
↕ 28.3 mm
inputRCA
BVC (external control for Bluetooth Audio Module B More)
Parts supplied1x Module TSA1020
1x 6-pin cable for Bluetooth module control
Channel2 (Stereo)
Bon.
Acheté avec un ampli TINYSINE TSA3118B Bluetooth aptX TWS 2x50W, le module fonctionne bien.
Connecté en Bluetooth (connecteur blanc) Il introduit quelques bruits parasites dans les HP, mais c'est très faible et disparait avec la musique.
Fonctionne aussi très bien avec les RCA connecté.
This review has been posted for TSA1020 Volume control module Source Selector RCA
