Passive Audio ladder Volume control module bit 256 levels by logic door
Passive Audio step volume controler 8bit 256 levels by logic door
This volume controller with 16 military quality resistors allows 256 level steps with 8 bit encoding per logic gate. This technology represents the best in volume control.
Reference : 11662
49,90 €tax incl.
41,58 € tax excl.
Shipping from France
Billing in France
Technical support in France
Volume controller
8 Bit 256 Steps passive resistor volume controller per logic gate
Contrôleur de volume passif à résistances 8 bit 256 niveaux par porte logiqu
This volume controller with 16 military quality resistors allows 256 level steps with 8 bit encoding per logic gate. This technology represents the best in volume control with potentiometers with manual switching Step Ladder.
By its design, it will meet the demanding designs in terms of Audio Fidelity. Its short circuitry and compactness will allow particularly complex fixtures such as level control of active speakers or stereo preamplifiers. It is particularly recommended because of its operation in place of the classic potentiometers and film and carbon track less accurate and less reliable over time. It may be necessary to use a buffer to get the desired gain when using pre amplification stereo audio.
This volume controller only requires a 12V VAC transformer in secondary voltage to operate.
Diagram
ARight line input
BRight ground input
CLeft ground input
DLeft line input
ERight line output
FRight ground output
GLeft ground output
HLeft line output
IVAC Voltage input
JGround power
KVAC Voltage input
Product typeStereo volume controller module, 8 bit with switched resistors
PotentiometerB50k ALPS
Module voltage power supplyFrom 12V AC to 15V AC
Contacts platingGold
Fixation holes spacing78 x 47mm
Dimensions86 x 55 x 24mm
Weight84g
This volume controller with 16 military quality resistors allows 256 level steps with 8 bit encoding per logic gate. This technology represents the...
