AKUSTIK Passive Preamplifier / 10k Source Selector
Khozmo Acoustic Preamplifier / Source selector 10k
By buying this product you get 32 loyalty points
Reference : 8684
324,17 €tax excl.
Including 0,25 € for green tax
This passive attenuator uses a precision resistor that is mounted in parallel with a 1% SMD mechanical resistance switch.
This resistor is connected to the potentiometer, which, depending on its position, more or less connects the output to ground, and thus makes the volume vary.
It is therefore the resistance R-In which conditions the minimum input impedance, when the potentiometer is at position 0.
Both passive preamplifier and source selector, this device with aluminum and wood finish will convince.
It is equipped with very high quality components assembled by hand with the utmost care.
Besides its magnificent realization, this volume controller hasof what is technically better in this field.
Features:/ Strong>
InputUSB 3.0
InputI2S
InputJack 6.35mm
InputMicro USB
InputI2S
InputUSB Amanero
InputJack 3.5mm
InputXLR
InputUSB XMOS
ColorArgent / Bois
StructureAluminium / Bois
Channel2 channels (Stereo)
Colissimo - TNT - SoColissimo
Top produit (aucune coloration ni perte, finition exemplaire)
Je cherchais un preampli passif de qualité pour relier deux sources à mon ampli de puissance. Celui-ci répondait à mes besoins. La finition est à la hauteur du prix. Aucune coloration ni perte audible. L'atténuateur est un plus (mais je ne l'utilise pas). Son seul défaut: le long, tres long délais d'appro (5-6 semaines dans mon cas, très loin des 2-3 semaines annoncées)
This review has been posted for AKUSTIK Passive Preamplifier / 10k Source Selector
