AUDIOPHONICS PRE-BD1404CH Preamplifier Volume Control Source Selector
2-channel preamplifier with volume control, three equalization bands and source selection 4 stereo inputs on RCA connector. Incorporates a double regulated linear power supply for each channel of the stereophonic signal.
4.7 / 5
Reference : 14568
215,00 €tax incl.
179,17 € tax excl.
Shipping date: 25-04-2024.
Shipping from France
Billing in France
Technical support in France
PRE-AMPLIFIER VOLUME CONTROLLER SOURCE SELECTOR
Double class A linear power supply, 4x RCA inputs, volume control, 3x equalization bands, 4x AOP LME49710
This carefully designed preamplifier and source selector (4 inputs) has two separate circuits for each channel of the stereophonic signal. Each of these circuits operates in pure class A and is powered by its own regulated linear power supply to provide extremely clean channel separation and preserve the signal finesse. Each channel is controlled by two operational amplifiers LME49710.
Class A preamplifier
The PRE-BD1404CH has an elaborate preamplification circuit with separate preamplified channels and separate power supplies. It offers volume control via a rotary potentiometer located on its front panel.
It also offers a three-band equalizer (Bass / Medium / Treble) to enable minor tone adjustments to find a pleasant balance depending on the specifictions of your analog audio installation.
A selector located on the front panel allows to completely bypass the tonal adjustment function in order to keep only the unprocessed signal in the preamplification circuit. A diode indicates the bypass status.
Source selection
In addition to its preamplification / volume control / three-band equalizer function, the PRE-BD1404CH offers a source selection function on its 4 stereophonic inputs (RCA connectors). The output connectors are mounted on its rear panel.
The stereo output, also on an RCA connector, is located on the same panel to allow clean and ordered wiring.
Finally the rear panel has a power connector (IEC) made for 220V voltages.
The source selection is made using a rotary selector located on the front of the device.
TypePreamplifier
Volume control
Source selection
Inputs4x RCA single-ended stereo
Outputs1x RCA single-ended stereo
Frequency response2Hz - 40kHz
Input impedance50K
Output impedance600Ω
THD+N0.003% @ 1kHz
AOP4x LME49710
Power supplyAC220V (Power cable NOT included)
Dimensions330x 210 x 60mm
Weight3kg
ColorSilver
7 reviews
Preampli haut niveau
Bonjour, le préampli a été très bien emballé, donc rien à signaler sur son aspect.
Le préampli est équipé de 4 ampli OPA1611 alors que la doc précise des LME49710. Comme ils sont installés sur des supports, ils peuvent être facilement remplacés.
Seul petit regret, le potentiomètre de volume aurait pu être un ALPS plus haut de gamme.
Les alimentations sont réalisées à partir de régulateur intégré avec un transistor ballast montés sur radiateurs. T° relevé 40 à 45°C.
Aux mesures, rien à signaler de particulier, si ce n'est un léger décalage de niveau entre les deux voies (
This review has been posted for AUDIOPHONICS PRE-BD1404CH Preamplifier Volume Control Source Selector
Acheté comme selecteur de sources , la fonction preampli est un plus avec les reglages basses /mediums/aigues et ou bypass .
Je trouve ce preampli très detaillé peut être un peu trop à mon goût avec mon ampli nc 250 ,enceintes magnat transpuls 1500 et ma source nvidia shield.
Je lui reproche un selecteur de sources et des potentiomètres sans graduations et 2 voyants rouge aveuglants.
Malgres cela , son prix vaut le détour et peu faire des heureux assurément!
Bon MAIS pas de cable d’alimentation!!
Bonne qualité de construction. Malheureusement, il était livré sans câble d'alimentation ! Je ne sais pas si c'est une erreur ou si c'est normal. Le préampli sonne bien. Il y a un peu de sifflement du préampli mais rien de plus. Il y a un clic d'interrupteur à l'allumage et beaucoup de bruit après l'extinction. Les contrôles de tonalité sont plus subtils que ce à quoi je m'attendais et j'aime ça. Dans l'ensemble, c'est un bon rapport qualité-prix et bien plus que ce que l'on peut espérer pour ce prix.
préampli Riaa
Bonjour, je voulais savoir si toutes les entrées sont identiques ou si l'une d'entre elles possède un préampli Riaa afin de brancher une patine vinyle...
Merci
Non aucun préampli phono sur ce produit.
Toutes les entrées sont niveau ligne.
Preampli
Très bon préamplificateur, bien construit et de qualité.
La qualité sonore est au rendez vous. Son clair, précis et détaillé. La restitution du bas registre est excellente. La séparation des canneaux se fait bien sentir, tout est sa place lors de l'écoute.
Les moins sont comme dans un autre commentaire, les lampes rouges interne qui ne servent pas à grand chose.
Moins convaincu par la section de correction de tonalité. En mode réglage de tonalité, pour ma part, je perd en qualité sonnnore, dynamique, et gain. Le son est moins naturel.
Assemblé avec mon ampli à lampe TAC,34 et mes enceintes wharfedale e50 en mode bypass, c'est un véritable régal auditif.
Satisfaction garantie avec ce petit preamplificateur dont le rapport qualité prix est bien plus que correct.
A recommender.
2-channel preamplifier with volume control, three equalization bands and source selection 4 stereo inputs on RCA connector. Incorporates a double...
