FX-AUDIO TUBE-06 MKII Tube Preamplifier 2x 6N3 DAC ES9018K2M CM6642 Subwoofer 24bit 192kHz Black
The FX-Audio TUBE-06 MKII is an affordable and efficient tube preamplifier. Its preamplifier stage is based on the use of a pair of 6N3 tubes. It is associated with a digital/analog conversion section using an ESS ES9018K2M DAC chip, a CM6642 USB interface or other quality components such as NE5532 and OPA2134 AOs. It is thus capable of a musical and warm restitution. It also supports audio streams up to PCM 24bit 192kHz.
4.5 / 5
Reference : 15811
99,00 €tax incl.
82,50 € tax excl.
Shipping date: 02-04-2024.
Shipping from France
Billing in France
Technical support in France
FX-Audio TUBE-06 MKII Préamplificateur à Tubes 2x 6N3 DAC ES9018K2M CM6642 Subwoofer 24bit 192kHz
Practical, its front panel is equipped with both a volume control, but also adjustments to adapt the bass and treble levels. It also benefits from a complete connectic with USB-B, Optical and RCA stereo input, and RCA stereo output as well as a subwoofer output.
Product typePreamplifier
Tubes2x 6N3
DAC ChipES9018K2M
USB InterfaceCM6642
Inputs1x USB-B
1x Optical Toslink
1x Stereo RCA
Outputs1x Stereo RCA
1x Subwoofer output (RCA)
MicrocontrollerSTM8s
AOPNE5532
OPA2134
Supported sampling ratesPCM up to 24bit 192kHz
Line output level3Vrms
THD+N< 0.5%
Frequency response20Hz-20kHz
SNR98dB
Supply voltage12VDC 2A
Housing materialAluminum
Dimensions133 x 179.2 x 35.7mm
Package1x FX-Audio Tube-06
1x Power supply
1x USB cable
OutputSubwoofer
ClassTube amp
Remote ControlN/A
2 reviews
très bon son mais ...
Le préamplificateur a été livré très rapidement un grand merci a audiophonics ! je l'emploi pour pré-amplifier un amplificateur classe d de 100 w ,le résultat est très bon en analogique puissance et intelligibilité du signal on peut augmenter les graves et les aigus ce qui n'est pas forcement une hérésie audiophile ...Cependant le dac n'est pas reconnu par les ordinateurs Mac et je n'ai pas trouver de pilote ( pas de notice explicite à ce sujet d'ailleurs le mode d'emploi et quasiment inexistant et en chinois !) sur pc ça fonctionne sans driver mais pas vraiment tester pour me faire une idée précise ..
les lampes incluse 6n3 son vraiment de piètre qualité ( 1 étais poreuse et a rendu l’âme) j'avais des 6h3n d’Ukraine qui on remplacé avantageusement les tubes d'origine,le son et vraiment meilleur maintenant . En conclusion un bon pré ampli pour le prix avec les inconvénients que j'ai cité plus haut mais je suis content de mon achat .
This review has been posted for FX-AUDIO TUBE-06 MKII Tube Preamplifier 2x 6N3 DAC ES9018K2M CM6642 Subwoofer 24bit 192kHz Black
Very good product.
I bought this dac/preamp to feed a headphone amplifier and i was stunned with this dac-tube preamp combo, my headphones never sounded so good, and i have a much more expensive high-end dac.
This is the best value for the money.
The FX-Audio TUBE-06 MKII is an affordable and efficient tube preamplifier. Its preamplifier stage is based on the use of a pair of 6N3 tubes. It...
