MUSICIAN MONOCEROS Preamplifier Balanced Class A Silver
The Musician Monoceros is a beautiful, high-end balanced preamplifier with a high performance Class A architecture and a completely discrete line input stage. Its volume control uses relay-controlled R2R resistors for constant output impedance and exceptional sound quality.
By buying this product you get 134 loyalty points
Reference : 15226
1 349,00 €tax incl.
1 124,17 € tax excl.
Shipping from France
Billing in France
Technical support in France
Musician Monoceros
Preamplifier Balancer Class A Silver
Musician Monoceros Préamplificateur Symétrique Class A Argent
Musician Monoceros Préamplificateur Symétrique Class A Noir
Class A balanced preamplifier
The Musician Monoceros uses a 60 step volume control, based on the use of a microprocessor and a relay control. The precision resistors used allow a perfect balance between the channels and ensure a THD+N of only 0.0003%.
Discrete power supply stage
The Musician Monoceros' discrete power supply stage features a 60W toroidal copper coil transformer. This carefully designed power supply ensures low noise and deep bass, while providing a rich, accurate sound with a wide soundstage.
Non-destructive volume control
The sound quality of a conventional potentiometer can vary with the volume level, due to a non-constant impedance. Here, the device uses a high-end, non-destructive volume control and correction algorithm.
DC coupling
The signal path takes advantage of DC coupling, without the use of coupling capacitors that can affect the sound quality. This design allows for a very low DC output voltage so that the signal loop can reach an ideal state.
Simple but complete connectivity
The Monoceros reveals a simple but complete connectivity, to adapt to most audio systems. There are two balanced XLR inputs and one unbalanced RCA input. For the outputs, the device also offers balanced stereo XLR and unbalanced stereo RCA.
Remote control
The Musician Monoceros comes with a CNC machined aluminum remote control, allowing you to control the unit remotely. All the functions of the device are thus accessible, directly from your sofa.
Product typePreamplifier
ClassClass A
Inputs2x Balanced stereo XLR
1x Single-ended stereo RCA
Outputs1x Balanced stereo XLR
Frequency response10Hz - 100kHz (-1dB)
THD+N0.0003%
SNR120dB
Dyanmic range> 120dB
Crosstalk-110dB
Input resistance20kΩ
Output impedance200Ω
Dimensions330 x 320 x 60mm
Net weight7kg
Supply voltage110/240VAC, 50/60Hz (Power cable NOT included)
ConsumptionStandby : 1W
Operating : 20W
Housing materialCNC machined aluminum
ColorSilver
Package1x Musician Monoceros
1x Remote control (CR2032 battery NOT included)
InputXLR
ColorSilver
ClassClass A / AB
Remote ControlYes
3 reviews
beaucoup de plaisir musical.
pour tout ceux qui en marre du son numérique comme moi avant de acheter ce préampli. c'est tellement bon que je me couche de plus tard en plus tard . c'est une merveille ne cherchais plus , a 2h. du matin je crois entendre une platine TECHNICS SL 1200. WAOUH.LAISSEZ LE BIEN CHAUFER . très économique en plus max 20w. REGARDER LE TEST SUR NIEW SOUND , tout ce qui est écrit est vraie et je confirme .
This review has been posted for MUSICIAN MONOCEROS Preamplifier Balanced Class A Silver
très bon son
très bon a toutes les fréquences .les sources numériques qui passent par lui deviennent vraiment analogiques . je suis très satisfait c'est ce que je voulait .
Je recommande à 100%
Bonjour,
Après 1 semaine d'écoute, Je dépose un long commentaire, car très peu de retour sur cet appareil.
Je n'ai trouvé que 2 essais sur le net.
Je souhaitais simplifier mon installation HI FI et c'est raté.
Je possède un convertisseur à sortie variable (M2Tech vaughn) relié en symétrique
à 1 Chord mezzo 140.
(câble XLR O2A Q Sublim)
Je me suis vite aperçu que la sortie variable sur le DAC ce n'était pas ça du tout!
A niveau modéré je n'avais plus rien , plus d'image stéréo , plus de grave, plus de BP etc...
Un ami a mis le doigt sur ce que je soupçonnais et ce que je pensais des réglages de volume numérique
intégré au DAC.
J'étais obligé d'écouter à un niveau sonore important pour retrouver de la Hauteur
et du détail .
Je me suis mis en quette de trouver un vrai Préampli avec un vrai atténuateur de volume.
En dessous de 2000€ c'est très compliqué de trouver.
Tout de suite, j'ai pensé à un atténuateur à résistance comme il en existe souvent
sur un préampli passif et préampli HDG.
Puis je suis tombé sur le Monocéros.
Techniquement, rien à dire, le tableau est même idyllique au vue du prix de l'appareil.
Le plus important c'est quand même comment il sonne .
Déjà, pour rester logique, il a fallu racheter un 2ème cable XLR Quintessence Sublim.
Bonjour pour la simplification de la chaine HI FI...
Inutile de dire aussi que je n'emmenait pas large d'intercaler 1 préampli à 1300€ entre 2 appareils à 5000€.
Mes doutes ce sont vite envolé dés les premières écoutes!
Je commence par ce qui m'a déplu, la finesse des timbres.
Ils sont pareil qu'avant rien de + rien de - et c'est peut-être sur ce point qu'un préampli
HDG fera la différence, mais je n'ai rien perdu sur ce critère donc c'est plutôt rassurant au final.
Car pour le reste.... c'est un sans faute.
C'est tellement mieux, que ça en est déroutant.
J'ai du comparer avant après pour comprendre ce qui ce passait réellement et ça après seulement 2h de chauffe.
Tout va plus loin.
BP élargie du grave à l'aigue, l'image stéréo plus stable avec de la hauteur proportionnel au niveau sonore.
Puis il y a cette sensation de pouvoir monter le volume sans rien déformer.
( A condition que les enceintes suivent)
Du détails en + qui devient tout à coup plus lisible qu'avant, mieux intégré aussi.
Il y a aussi un coté apaisé que je n'avais pas et que je n'ai jamais eu.
Cet appareil apporte beaucoup pour son prix , surtout si ses qualités et sa conception
perdure dans le temps, car c'est la grosse inconnu pour tout appareil hi fi.
mention spéciale pour le grave maitrisé et qui m'a bluffé.
Quand je pense qu'on peu encore travaillé l'optimisation avec 2 fusibles et un vrai câble secteur....
 (5)
The Musician Monoceros is a beautiful, high-end balanced preamplifier with a high performance Class A architecture and a completely discrete line...
