FX-AUDIO TUBE-01 Valve 6J1 Stereo preamplifier Silver
FX Audio TUBE-01 Valve 6J1 Stereo preamplifier Silver
4.9 / 5
Reference : 10996
29,90 €tax incl.
24,92 € tax excl.
Shipping from France
Billing in France
Technical support in France
The preamplifier FX-Audio TUBE-01 Tube Buffer 6J1 is a smart little tool to improve the sound of a desktop DAC or a HiFi installation. Featuring a gold-plated stereo input and output, it will be a quality companion coupled with a Class D power amplifier to restore dynamics and sound to any installation lacking vividness.
For the price offered, this device has qualities usually absent in this category.
A excellence for all enthusiasts who want a high quality, affordable tube preamplifier.
This preamp has a pretty important gain to boost a weak level source.
When using a fixed 2V source, the volume knob is pretty sensitive, as the gain ratio 1 is reached @ 30% of it's position.
Specifications:
  • Output signal : 6V Max
  • Input sensitivity : 0 - 2V
  • Gain : 20dB (x10)
  • Impedance: 600 Ohm
  • Frequency response: 20hz to 20hz
  • Noise Ratio: 100dB
  • Distortion 1000 mV 0.1%
Inputs and outputs:
  • An RCA Plated Gold Input
  • An RCA Plated Gold Output
  • Input Jack DC 5.5 / 2.5mm (Compatible 5.5 / 2.1mm)
Tube compatible:
EF95 / 6AK5
Dimensions and weight:
  • W 100 x L 95 x H 32mm (65mm with tubes)
  • Weight: 480g
  • Color facade: Silver
Adapter 220V AC to 12V DC / 1A, and tubes provided.
ColorSilver
ClassTube amp
14 reviews
Bon service client, à l'écoute et disponible.
J'utilise ce petit préampli en complément d'un ampli Denon PMA-520 ae sur une simple entrée Line, le résultat est très satisfaisant.
Un grand merci à vous.
This review has been posted for FX-AUDIO TUBE-01 Valve 6J1 Stereo preamplifier Silver
Incroyable !!
Ce minuscule préamp à un son incroyable, il faut juste mettre des bons tubes NOS ( j'ai mis des Sylvania ) et remplacer le potar voir comme dit plus haut " En réalisant un pont diviseur avec une résistance 47 kohms série et une 1.5 kohms parallèle "
Je ne sais pas jusqu'où il peut aller ... en remplaçant des condos ou des résistances qui sont sur le trajet du signal ... à tester ... !!
Aussi une alim linéaire ou sur batterie ...
Je pense que le potentiel in finé est très très élevé ... pour un prix modique ... !
True tube sound for a budget price
Excellent product. I like it very much!
Excellent !
Très bonne facture pour ce petit préampli, avec un très bel équilibre sonore. Petit look sympa aussi.
une révélation
petit préampli a lampe vraiment extraordinaire déja avec les tubes d'origine s'est très bon , mais avec des tubes nos américain s'est juste excellent finit les préamplis hors de prix .
couplé a un blocs de puissance behringer a800 classe D dac smsl sanskrit et enceintes proac studio 130 elles n'ont jamais aussi bien chanté .
a consommé sans modération .
encore merci a l'équipe d'audiophonics pour vos bons produits .
