TINYSINE TSA1110 Volume Control by Bluetooth Android / iOS Compatible
TSA1110 Bluetooth Volume Control Android / iOS Compatible
This TinySine TSA1110 will allow you to control the volume of your audio system of your choice via the rotary knob on the case or remotely, directly via your smartphone.
Reference : 12871
25,90 €tax incl.
21,58 € tax excl.
Shipping date: 29-03-2024.
Shipping from France
Billing in France
Technical support in France
TinySine TSA1110
Bluetooth volume control Android / iOS compatible
TSA1110 Contrôleur de volume Bluetooth compatible Android / iOS
This TSA1110 will allow you to control the volume of your audio system of your choice via the rotary knob on the case or remotely, directly via your smartphone. For remote control, the TSA1110 uses your smartphone's Bluetooth. Via a dedicated application, you will be able to act on the sound volume thanks to a digital potentiometer and this up to a distance of 30m. The application is available under Android and iOS.
The TAS1110 is very simple to install. It has 3 ports at the rear: an audio input, an audio output and a 12V DC Jack power plug (not included).
Warning: The TSA1110 is not a Bluetooth receiver. It simply allows remote volume control via this technology.
Cauton : the output level is 4V, which is more than regular line output level. Take this into account when setting the volume.
Caution to use this item, your amplifier must have capacitors on its input.
How to use the smartphone application
  1. Download and install the smartphone application. Android device users can download the.apk file and install it. For iOS users, the application is available in the AppStore by searching Lazybone dimmer BLE.
  2. Open the application and activate Bluetooth on your phone.
  3. Go to the Bluetooth menu and click "Connect Device". The phone will search for available Bluetooth devices. The "TSA1110" should then be displayed. Select it.
  4. You can now adjust the volume of your system directly from the screen of your smartphone by turning the knob displayed. The button at the top left activates the MUTE mode.
DC 5V or DC 12VCheck the mark on the device
Output leven4V
Max control distance30m (without obstacle)
Bluetooth4.0
CompatibilityAndroid above à V2.2
iPhone 4S or more
Power supply (not included)12V DC - Jack DC 5.5/2.1mm
Dimensions96 x 41 x 20mm
InputJack 3.5mm
OutputJack 3.5mm
ClassN/A
2 reviews
Tinysine TSA110 super pratique
acheté pour piloter le volume de mon ampli à tubes qui ne dispose pas de controle de ce dernier, celui ci etait intercalé entre l'ampli, un selecteur audio video vsw41 et enfin un lecteur reseau, après maintes essais infructueux je peux doneravant l'utiliser, c'est vraiment une solution bien pratique et confortable quand on ne peut pas controler le volume de son ampli, utile, pratique et pas cher pour le service rendu, merci.
This review has been posted for TINYSINE TSA1110 Volume Control by Bluetooth Android / iOS Compatible
ingénieux
Recherché et utilisé pour piloter 2 amplis intégrés " vintage "sans télécommande, entre un sélecteur de sources et un sélecteur d'amplis.
Mise en oeuvre facile et simplicité d'utilisation. Confort ajouté.
Contrôle du volume très fin. Parfait pour mon usage.
This TinySine TSA1110 will allow you to control the volume of your audio system of your choice via the rotary knob on the case or remotely,...
