UI 39/13,5 2x6V 1,67A 18VA
This encapsulated transformer is ideal for PCB mounting. It will allow you to provide your system with quality food, offering a two-compartment internal design.
Power | 18VA |
Input voltage | 2x115V / 1x130V |
Frequency | 50/60Hz |
Output voltage | 2x6V 1,67A |
Dimensions | 68 x 28mm |
Caution: for 230V installation it is absolutely necessary to connect the 115V pins.
Schema 1
Input 230V / Output 2x6V
Schema 2
Input 230V / Output 1x6V
Schema 3
Input 115V / Output 2x6V
Schema 4
Input 115V / Output 1x6V
Color | Blue |
Primary voltage (V) | 230.0 |
Primary voltage (V) | 2x 115.0 |
Secondary voltage (V) | 6.0 |
Power (VA) | 18.0 |
