Noel C.
Andrea T.
excellent
Rien de spectaculaire...
Vasileios K.
A great dac for the money
EIZZ EZ-301 Gold plated OFC Copper Binding posts Ø16mm x 61mm (Pair) - reviews - There are 20 reviews.
Iulian M.
Verry good with minor issues.
It does not seem to have any iron in the conducting part of the connector. Just the golden cock ring has some iron and I just cut it of (seems stupid to include it, the connector looks better all black) as it could act as a small filter (like a ferrite bead). The cap is aluminium but I dont see how it could affect the sound, a better solution may have been plastic like WBT connectors. These connectors are my go to as it seems to not affect the sound (compared with just wire) and are way cheaper than WBT.
Dario G.
Très très bien
Marque et produit sérieux ! Rapport qualité prix sans commentaire !
Absolument recommandé.
NICOLA G.
Very good
Connections are often underestimated by audiophiles. Dirty rca inputs and poor quality binding posts degrade the audio signal more than one might believe. I replaced the crappy brass-made binding posts on my speakers (cornscala type d) with these Eizz and the difference was stunning. Better imaging, more extension and presence, no traces of harshness, more silence between notes. One of the best buys in my music and hifi lover carrer! Excellent product and excellent service by Audiophonics!
Etienne L.
Du sérieux!!!
Je confirme la qualité de construction et c'est bien du cuivre...
Pour passer mes câble 2,5mm j'ai percé les fiches avec un forets et c'est parfait et toujours solide (il y a une surface plane assez large)
Pas besoin de se tracasser pour l'encoche ou le détrompeur il suffit de changer l'ordre des rondelles de couleurs...
La soudure est parfaite, un bon rapport qualité prix
Gurvan B.
Pas mieux pour le prix
Qualité super! Un des rares bornier avec une faible masse, de plus c’est du vrai cuivre sous le placage or. Le prix est 10x moins cher que certaine marque pour la même qualité du conducteur… Je vous le recommande pour tout type de haut parleur si vous avez prit un bon câble pour plus de transparence, ce bornier sera faire passer le signal parfaitement.
Roland J.
Attention au diametre percage indiqué
Audiophonics indique un percage panneau de 8mm, c'est complétement faux il faut percer à 12 mm et faire des encoches pour pouvoir insérer les petits débords plastiques intégrés anti rotation.
Grrrr pas merci Audiophonics pour cette info erronnée, ça a été une vrai massacre pour aggrandir des trous déjà percés sur une plaque inox
Frederic G.
Excellent mais…
J’utilise depuis quelques années exclusivement du fil nu entre l’ampli et les enceintes. Le seul inconvénient de ces excellents borniers faible masse est qu’ils ne permettent pas facilement le serrage d’un câble nu au-delà de 2,5 mm2 car ils ne possèdent pas de trou central ! Pour palier à ce problème, j’ai fait une fourche au câble en divisant le multibrins en deux sur 2cm. Pas de soucis avec du monobrin, une boucle suffit.
J’ai donc retiré les gros (et jolis) borniers en laiton plaqués or d’origine et le moins que je puisse dire est que je n’ai pas été déçu de l’amélioration sonore!
Ces connecteurs faible masse sont simples mais bien construits et plus robustes qu’ils n’y parait. Vous ne vous ruinerez pas et vous pourriez bien être surpris du résultat.
Matteo A.
Super prodotto
Resa sonora eccellente, molto dettagli, pulizia migliorano tutti i parametri sonori.
Rapporto qualità prezzo prestazioni altissimo...
ALTAMENTE CONSIGLIATI
Michel C.
Nice but one small remark
Used these to change the cheap binding posts on my amplifier. I believe in excluding big chunks of brass/metal (same principal like WBT connectors). These ones are much cheaper but one remark, these are excellent for banana plugs but for spades the contact area is really small.
Stephane N.
En remplacement des borniers "laiton doré" sur des SA 2K, je ne sais pas si la différence m'a sauté aux oreilles .
Simplement désormais, pas de mélange entre le câble, les fiches bananes et fourches, et ces borniers. Du cuivre d'un bout a l'autre.
Très bon produit.
PHILIPPE D.
Fiches de très belle qualité, de plus isolées.
Belle fabrication
TECCE V.
Eccellente
Conduttore di puro rame come nelle realizzazioni migliori. Nulla di simile a questo prezzo. Attenzione alla lunghezza della vite filettata: non consente il montaggio su pannelli di alto spessore.
christ yannick b.
Légère différence
J'ai changé les borniers de mes Triangle Borea br02 juste pour voir si ça faisait une déférence. Après une comparaison A-B de 5 minutes. J'ai cru déceler moins de distrosion ou un effet placébo. Les borniers d'origine devait déjà être bon, ils ne réagissait pas aux aimants. Je dirai que j'ai gagné 1%.
Faut dire que j'avais déjà tout changé dans les enceintes (crossover de meilleur qualité et câblage interne occ) .
Je prendrai le modèle au dessus pour mon ampli.
Pour le prix ça doit être un super upgrade pour des enceintes vintage ou un vieux ampli.
Nicolas G.
L'essentiel.
Voilà des prises hp qui vont à l'essentiel, la meilleure continuité possible entre deux maillons d'une chaîne haute fidélité. Du cuivre, juste ce qu'il faut, un plaquage contre l'oxydation et assurer un bon contact..., c'est tout. Et pour ceux qui trouveraient que çà fait trop plastoc (et oui c'est du plastoc), il existe d'autres modèles beaucoup plus "bling, bling" avec des matériaux rares et tout, et tout..., l'écoute doit certainement être meilleure..., je laisse certains le croire, à la grande joie des fabricants et vendeurs. Moi mon choix est fait!
Romain G.
Génial!!
Après avoir récupérer un harman kardon citation 16 j'avais du mal a savoir pourquoi cette appareil avais si bonne réputation..
Après le changement des connecteurs RCA par des modèle en cuivre, le changement avais été très surprenant, tout était plus propre, c'est pourquoi je me suis lancé dans le changement des bornier HP assez difficile à atteindre, mais ça en valait la peine!
Un son plus chaud plus défini, mais le plus gros gain est au niveau du grave! Meilleur profondeur, plus précis.
Je pense que la difference est encore plus grande sur cette appareil de 45ans..
En tout cas maintenant il fait des merveilles sur mon système très HDG (focal sopra n2)
Andrei M.
Recommend
Good product. Made of high quality. I hope they're really made of pure copper.
Jean Luc m.
Très bien
Parait un peu plastoc de prime à bord ,mais la qualité est présente.
Une fois installées sans difficultés particulières,le passage à l’écoute révèle de suite une sensation de plus grande douceur ,peu être plus de détails,surtout dans le haut du spectre et surtout j'ai l'impression d'un meilleur respect des timbres ,qualité à la quelle je suis très attaché.
Bref,pour le prix,apport d'un mieux subjectivement mesurable.
Romain B.
Très bon produit
J'en ai commandé 2 paires en remplacement de borniers à pinces sur des enceintes. Le produit est lourd, bien fini et assure un excellent contact. Parfait.
Jan O.
Excellent value for money
but beware of the tightening force of the nut, the thread does not last what brass thread. There are not any hole for naked wire.
Probably you will not find any cheaper terminals with OFC copper core.
anael R.
Excellent rapport qualité prix
Cela fait déjà le 3eme set que je commande.
Pour le prix, c'est imbattable.
Un des rares à être en cuivre et non en vulgaire laiton (meilleure conductivité/excellent en courant fort).
Peu de métal comparé à d'autres marques et c'est tant mieux, dénaturera moins le signal en provenance du câble HP (design se rapprochant du low-mass).
Soudure nickel sur la tige de contact. La fibre de verre est très résistante et apporte un fini très HDG, neutre et sans fioriture.
Les détrompeurs panneau permettent une fixation aussi bonne et fiable qu'avec des connecteurs Mundorf EVO (même système).
Un seul demi-bémol, minuscule détail, le contact intérieur cylindrique qui va recevoir la fiche banane n'est pas 110% ébavuré, du moins visuellement, mais sans effet négatif sur la qualité de connexion.
Ces connecteurs ne rivaliseront pas tout à fait avec des WBT en termes de fini, mais seront parfaits pour leur tâche, à un prix de raison !!! :)
 (6)
EIZZZ AUDIO offers excellent quality products made of innovative raw materials with top-of-the-range finishes. These gold-plated OFC Copper...
