Noel C.
Andrea T.
excellent
Rien de spectaculaire...
Vasileios K.
A great dac for the money
ESS ES9038Q2M DAC Module I2S Optical Coaxial 32bit 384khz DSD256 - reviews - There are 8 reviews.
Panos M.
Quite nice to build uppon
For its price it is really a no-brainer. Using a few of them and if you are up to it, use muses3 opamps, change the clock and use dedicated cpu's on all sections, removing the onboard regulators.
Then this baby can sing
Thomas Z.
Worked without problems right from the start. The need for unsoldering and re-soldering the 0R SMD "resistor" for using wih a dual power-supply is unconvenient, much better here would be a jumper with two positions.
Sound wise (until now I only used the optical in) already great, really met my expectations. Output stage with elco's in signal path leaves room for individual improvements.
Eugen G.
I'm very satisfied
The circuit board is well and cleanly made.
I bought them for the conversion -
Power supply -
3X LT 3045
3X LT 1963
and I / V output -
3X LM 49720
Eugen G.
I'm very satisfied
Power supply -
3X LT 3045
3X LT 1963
and I / V output -
3X LM 49720
Eugen G.
I'm very satisfied
Power supply -
3X LT 3045
3X LT 1963
and I / V output -
3X LM 49720
Anders M.
Fantastic DAC!
Tried this ES9038Q2M for testing. For the relatively small price paid for this board, you get a very good DAC. Tested with a single rail 15V supply and connected Raspberry Pi 3B+ (over I2S) with separate 5V SM supply. Using piCorePlayer 4.1 (I-Sabre-ES9023 DAC, native/DoP DSD Squeezelite binary, card control: 384k) the sound is amazingly clear and distinct and the bass is well-balanced. You can pin-point the instruments in a symphony orchestra. Was able to play DSD128 files (DoP) without any problems.
The board comes with a 5532D opamp. Looking forward to testing the board with a Muses opamp and a dual rail 15V linear PSU.
József K.
Great product
I'm wondering what the voice will be after burning
Icard Gras Axel H.
top
top class pour un tarif cheap cheap cheap .
This DIY module based on a DAC I2S ESS ES9038Q2M offers many possibilities of use in a compact card format. It has I2S, SPDIF Coaxial and Optical...
