Noel C.
Andrea T.
excellent
Rien de spectaculaire...
Vasileios K.
A great dac for the money
ETI LEGATO Schuko Type E/F Power Connector Gold Plated Pure Copper Ø20mm - reviews - There are 4 reviews.
Alexandru Ovidiu A.
First class connectors
Used on a Furutech 762 AC cable. Very neutral, very dinamic sound. Very good connection points and very clever and efficient cable holding system. Used on Amplifier.
Michael N.
Superb mechanical and audible quality
Solid and stable mechanical construction. Everything fits here, easy but efficient. Hugh difference in regard to "gold plated" compared to other connectors!
Tonal very fine, well balanced and detailed - best connectors I ever bought!
Jacques B.
Superbe produit
Qualité de fabrication irréprochable permettant une haute qualité de contact et d'assemblage avec le câble secteur. Transparence et qualité de timbrage superbe par une transparence hors norme. A mon sens, plus neutre que les connectiques Furutech, sans nier leurs qualités également. Superbe mariage avec le secteur DPS 4.1 Furutech avec un apport concret dès la mise sous tension. Bravo !!
Grzegorz B.
One of the best power connector
I tried almost all power connectors for better audio equipment, the are almost the best. You can mount with or without crimp sleeve (better and safer with), in Schuko up to 6mm in IEC up to 4mm. In can is enough space to prepare cable comfortable (much better than Furutech 46/48/50 and cable holder is better than in Furutech, because don't damage cable like jaws in Furutech. Screws that merge both halves are screwed in aluminum, not like Furutech in thin plastic.
 (5)
The ETI Legato Schuko connector benefits from a high-end construction based on the use of high quality components for optimal conductivity. Thus,...
