Patrick B.
Pour ibasso dx340
Ibasso amp16 change la DONNE LA QUALITÉ DE SONORITÉ EST SUPÉRIEUR SURTOUT SUR LE MODE TUBE HEUREUSEMENT QUE AUDIOPHONICS...
Arvydas V.
A
I put these in place of Audyn KP-SN. The sound is much clearer, and there is more of everything in the music. I recommend it.
Mohammed B.
Top Spulen und beste auf dem Markt
Die Jantzen WAX COILS spielen fantastisch warm gemütlich detailreich musikalisch und sehr angenehm.
Im Vergleich zu Mundorf...
LOXJIE A30 Class D Amplifier Infineon MA12070 Bluetooth 5.0 2x50W 4 Ohm - reviews - There are 16 reviews.
Markus H.
A great amp, unbeatable for the price
Extremely clean, crisp and analytical sound. No discernible noise, even if you hold your ear directly to the tweeter. This also speaks in favour of the high quality of the power supply unit. Its treble is a little too strong for me personally, but I easily reduced it using the tone control. Operation is very simple and the workmanship is very high quality. Thank you, Audiophonics, for the fast and safe delivery.
Nathalie M.
Précis & Musical
Fonctionne très facilement en Bluetooth (mais juste en 48 kHz...) en délivrant une puissance modeste mais plutôt correcte pour 20-25 M2.
Ne chauffe pas du tout et sans aucun bruit parasite.
Pas encore testé en Hi-Res, via USB ou fibre Optique mais déjà étonnée par la qualité musicale restituée.
Bert D.
Very diverse and good looking
It's a very handsome and diverse device and above all very good sounding.
Simon R.
Loxjie A30
Ordered this little unit because I needed a new amplifier for speaker measurements. The ASR review showed perfect load independent linearity, and that was exactly what I needed for the purpose. In short, it all works as expected, the connections give me all the possibilities to input the measurement signals. And by the way, a short sound test via spdif convinced me so far. For a second sound system, or perhaps as a travel companion, the device is a great option. Small criticism: The device tilts a bit, because one foot is sunk deeper than the others. Since this is easy to fix and does not affect the function, I still give all stars as a rating.
David O.
Excellent !
Vraiment ravi de mon ampli. J'avais, juste avant un FX-AUDIO, (D802C) qui faisait le taf musicalement mais qui avait deux soucis, la connectique : pas de sortie Subwoofer et l'écran qui a mal vieilli et qui était illisible, à part dans le noir total... Pour mon caisson je le branchait donc en parallèle sur mes enceintes mais bon...
Là on a produit vraiment au top, je le préfère 100 fois ! Déjà la finition, l'écran magnifique à côté de mon D802C. Couleurs personnalisable, dimmer automatique ou non, sortie Sub, et SURTOUT plus progessif niveau volume. Dans mon cas je suis branché en USB sur mon PC (donc en système 2.1 caisson Magnat et enceintes maison) Avec le FX-AUDIO, avant, même volume à 1 c'était trop fort une fois tout le monde couché, mon PC étant sur le palier devant les chambres... C'était tout ou rien, à moins de me brancher en analogique mais cela n'aurait aucun intérêt. Là je trouve un volume progressif parfait sur ce LOXJIE. Franchement, pour 30€ c'est le jour et la nuit.
 (3)
Maxime D.
Perspicace !
Eh oui, Perspicace, c'est le mot qui décrira au mieux ce petit ampli de chez Loxjie que je ne peux que conseiller. 2 semaines d'essai et vraiment pas déçu de mon achat. Pour ceux qui veulent se créer un petit 2.0 / 2.1, pour le prix, foncez ! Me concernant il est couplé à une paire d' Klipsch RB-81 II et le rendu sonore est vraiment très très bon, j'ai joué un peu avec le treble pour régler et le tour est joué. Bref, rien à redire pour le moment, à voir dans le temps !
Nikos K.
Tout simplement génial pour l'argent. Quant au magasin AUDIOPHONICS, expédition incroyablement rapide et service impeccable.
Damien N.
Très complet, de bonne qualité et performant
Ce tout petit ampli fait bien ce qu'on attend de lui. En l'occurrence il remplace ma vieille chaîne compacte qui sonorisait mon PC. La finition est bonne, jusqu'à présent je n'ai pas eu de mauvaises surprises et je l'utilise principalement avec les entrées bluetooth et optiques.
J'apprécie les réglages disponibles pour ajuster les graves et les aigus, et c'est ce qui me l'avait fait choisir face à un Elipson Music Center BT équivalent. Alors ça ne donnera pas autant de contrôle que l'égaliseur à bandes de ma vieille Sony mais ça suffit largement.
Andrej V.
good amp
excellent dynamic sound, subwoofer output works well, laptop with Windows 11 and mobile phone with Android 11 connects immediately to usb-no need drivers, tv via optical input plays great, overall I'm happy with the purchase and delivery speed I just need to replace the speakers for something better - )
Charles-Eric S.
Excellent !
Merci encore à Audiophonics qui malgré les retards de fabrication m'a tenu informé.
Bien reçu, bien emballé.
Très bon ampi, pour son prix, c'est même assez bluffant.
Effectivement quelques défauts mineurs Comme la télécommande assez directive, et pas d'affichage de l'échantillonnage en mode USB.
Ceci dit, quel son !
J'ai des enceintes maison Triangle et je les redécouvre.
Très bonne qualité de fabrication.
Que dire d'autres, sinon que je suis aux anges...
Didier L.
Based on favorable reviews; I decided to buy the Loxjie A30.
https://www.audiosciencereview.com/forum/index.php?threads/loxjie-a30-amplifier-review.17547/
Since I wanted to buy from a reseller inside of the EU; I placed
my order at Audiophonics. With this decision I was very satisfied.
Due to the december holidays and the COVID-19 pandemic; shipping from the manufacturer in China took more time. To my delight, this was clearly communicated by Audiophonics via e-mail. When the Loxjie A30 was available; I received a postal tracking code and less than a week later the Loxjie A30 itself. The Loxjie A30 was neatly packaged and functions as reviewed and advertised.
Matthew d.
Received mine yesterday! And I have to say that I am quite pleased with it! The case itself has a nice feeling to it, appears very clean. Soundwise out of the box it sounds very clear, hooked it up to my Floorstanding KEF Q5's. It has no over saturated bass or treble, rocks the building without going above '35' of soundvolume (unable to hold a conversation at this volume without yelling). Bluetooth pairing goes without a problem aswell. Only thing that's less charming is the IR remote, you really gotta point to the lcd screen otherwise it just wont function.
P.S. mine came with the 'new' power supply that previous owners got as replacement
Big thumbs up from me!
Emmanuel D.
Très bon produit pour le prix
Très heureux de ma première journée d'écoute avec le LOXJIE A30 sur des Tangents spectra X5 et en source un Rasp3 ALLO DIGIONE.
Le mode Direct est correct malgré certains avis critiques.
Il réagit bien à ma petite playlist de test dans tout les styles (Dire Straits - Idris Muhammad - The Midnight - Recoil - Masaaki Suzuki).
J'ai débranché sans peine mon ADVANCE ACOUSTIC X-I60.
Merci Audiophonics pour votre réactivité.
Sébastien S.
Très bon qualité/prix, attention à la mise en oeuvre
Très bon ampli, mais attention aux associations.
- nécéssite enceintes transparentes et réactives
- très sensible au câble (d'enceinte) de ce que j'ai expérimenté, en particulier avec un câble de section insuffisante, clair manque de basses. Avec le "SOMMERCABLE SC-ORBIT 240 MKII 2x4mm2" vendu sur ce site, c'est tiptop!
- seul point négatif pour moi, il manque l'affichage de la fréquence d'échantillonage (en usb, en tout cas c'est juste indiqué "connected").
David G.
meme avis que Valery H.
Meme avis que Valery H ! pret a le revendre !
je vais essayer les settings recommendes ici et voir si mon jusgement change mais de base il n'y a rien de bien sauf si usage avec un caisson de basse ....
Bonjour, nous pensons que le problème est ailleurs ...
Le produit en lui même est exceptionnellement bon dans cette gamme de prix :
Valéry H.
Très bon ampli intégré
Je ne peux faire que la comparaison avec mon smsl ad18 et mon ampli av Yamaha.
Utilisé depuis 15 jours sur des Dali zensor 5.
Mes premières impressions ont été plutôt mauvaises.
Pas de profondeur, des presets inutiles et un mode direct sans plaisirs aucun. Peut-être la faute à mes enceintes..?
A deux doigts de retourner le produit malgré un sens de la séparation qui m’a beaucoup impressionné.
Puis je me suis mis à peaufiner l’eq et bingo!
Chaleur profondeur et plaisir. Cet ampli surpasse en plaisir mon ex smsl.
Bien évidemment je ne cherchais pas une écoute analytique. J’ai des enceintes de monitoring dans mon studio d’enregistrement et ils font le job. Je cherchais du plaisir d’écoute et je l’ai trouvé.
Mes réglages en feront hurler certains mais je suis obligé de poussé les basses à + 7 et les trebles +5. C’est le prix du plaisir. J’en suis extrêmement satisfait.
C’est un avis de passionné mais également de musicien.
 (3)
 (3)
With the A30, Loxjie offers an excellent Class D amplifier that is powerful, compact and affordable. It features excellent components for great...
