christian b.
Il était temps...
Acheté pendant le confinement j'avais décidé de tester le changement du câble secteur sur mes électroniques. Plutôt...
Cheung T.
Excellent cable
This is an excellent cable for high end audio. Although it is mentioned to have 50 strands of 0.25mm wire, I can only find 48...
Pascal A.
Exceptionnel
Je l'ai acheté ici il y a quelques mois. Incroyable. Rapport qualité prix bousculant beaucoup de references beaucoup, mais...
NEOTECH NEMOS-3080 Speaker Cable UP-OCC Copper 2.1mm² Ø12.5mm - reviews - There are 12 reviews.
Davor F.
Clean and defined cable
After months of listening i can say that this cable fulfilled my expectations.Character of this cable is neutral but not analytical and cold,it's flowed and polite on high frequency range.Only when the recording is bad will it be felt, but never so much that it will bother you.Give it a good source and amplifier and it will show its quality in a positive way and put a smile on your face.Greetings from Croatia with one satisfied customer who enjoys every musical moment with this cable.
And i must Thank you Audiophonics for offering another excellent product for us music lovers at an affordable price.
Fabian b.
Musicalité. Equilibre detaillé
Monté avec cosse cuivre occ et fixé au trou des borniers. Simple et trés efficasse. Prendre son temps pour enlever la gaine et pas oublier la gaine fine transparente sur le fil. Quatre fils plat total 2mm2. Les enfilé apres traitement au desoxi gold et sertir a la pince. Attention pas de blindage. Evité de passer ses câbles pres de source electrique. Les iem sais pas bon vous pouvez si probleme acheter ici ine gaine cu etamé. Tres efficasse qui n influe pas les perf. Recommander
Lars H.
High quality sound
Excellent cable for current demanding speakers and matching powerful amplifier Effortless delery in the hole frequency area that my speakers can deliver Relaxed, full of details and never getting harsh in treble even at high listening levels Super satisfying
Joerg K.
Excellent Cable for reasonable price
Sound is excellent, very broad and deep soundstage.
Clear without irritating highs. Bass is also ver accurate.
To remove the insulation is very diificult and time consuming, also the termination with connectors is not that easy.
Still the sound quality was worth all the hassle.
Michael B.
Stunning cable
I have used many €20-€30 p/m cables and so glad I jumped to this price level and even more so that the sonic improvements have been worth every penny.
Naturally, the first few weeks are a little light and muddy in the bass, but other out of the box includes more air around vocals abs terrific timing.
A very worthwhile cable upgrade.
Angelo P.
Clean, dynamic and detailed sound, harmonics of instruments well reproduced. Great cable.
Michael B.
Just WOW
Although the cables are yet to burn in fully, the difference in quality over my various previous brands is astonishing. I've had Supra, QED, Audioquest etc. and the Neotech's are just gorgeous.
All the subtle details are there, plus a few more. It's astonishing just how FAT the sound is. Everything just sounds more realistic than before and with more presence and warmth than I am used to.
The quest for clarity is usually at the expense of musical warmth and realism, but not with this cable. A truly excellent upgrade.
tim c.
Neotech solid core
Was used for Avr system, excellent cable for center speaker, usual Neotech characteristics, a natural relaxed sound but packing a punch when needed, seems to be a bit of a hidden gem in the world of top end speaker cables
Dimitris P.
Excellent upgrade
This was a very good upgrade indeed from my previous cable, which was a ofc tin plated good value but inexpensive cable. Face-lift is the list I could say. Right out of the box much detail revealed, deeper and more bass, it felt that my system almost needed no equalizing anymore. This is not to say that this cable is pre equalized but just maybe it brought forward my systems character. now my accuphase and Sopra1's no1truly sing. I was and still am impressed. Next revelation was my Amp new power cable which improved much the imaging. I terminated just one side (speaker) with spades, red copper from yarbo sc1005Y. Amp side left it bare cause that was best suited for my amps type of binding posts, Preparation was easy, cable its not so elastic due to solid core though, so better not force it much. You just need to straighten it by hand quite a bit before installing. Its not expensive cable compared to others, that's really good cable for not so power-hungry systems, it has a 2.1square mm thickness.
 (4)
Patrick R.
Belle qualité de cable
Ce cable est équilibré, l'aigu est particulièrement doux et détaillé, les graves sont tendus. Se révèle après une très longue période de rodage. Le choix des connecteurs est important. Attention au montage, il y a de nombreux conducteurs à dénuder et leur assemblage peut-être délicat (1 étoile en moins). Il y a un tuto video sur le net qui peut aider.
 (6)
Georges N.
Excellent
Un câble intelligemment construit. Après rodage, une neutralité et un équilibre remarquables. Les distorsions ou duretés disparaissent. Un fourmillement de détails et de nuances, superbe dynamique y compris sur les plus infimes détails, une excellente tenue dans l'infra grave et le grave, défini et serré à souhait, les timbres sont superbes! Quel naturel ! Quelle ampleur ! Quelle profondeur ! (si le système et les enceintes le permettent !)
système: Platine CD Audio Aéro Capitole - Préampli DAC Vermeer Audio TWO- Ampli Line Magnetics LM 219IA - enceintes Tekton Design Electron SE
 (3)
Igor N.
NEMOS-3080 Loudspeakers cable UP-OCC
Wonderful cable. Flat mono-core + UP-OCC copper gives remarkable detail and sound completely without distortion in comparison with a conventional multi-wire cable. A wonderful scene and outstanding detail in sound!Thank you store AUDIOFONICS.
 (3)
The NEMOS series from the manufacturer Neotech is the culmination of long research in the field of audio cables. The  Neotech NEMOS 3080...
