christian b.
Il était temps...
Acheté pendant le confinement j'avais décidé de tester le changement du câble secteur sur mes électroniques. Plutôt...
Cheung T.
Excellent cable
This is an excellent cable for high end audio. Although it is mentioned to have 50 strands of 0.25mm wire, I can only find 48...
Pascal A.
Exceptionnel
Je l'ai acheté ici il y a quelques mois. Incroyable. Rapport qualité prix bousculant beaucoup de references beaucoup, mais...
NEOTECH NES-3003 MK2 Speaker Cable UP-OCC Copper Silver Plated 4x1.3mm² Ø19mm - reviews - There are 4 reviews.
Salvatore R.
exceptional cables
exceptional cable, remarkable 3D image, the instruments appear more in focus and great musicality.
Excellent audiophonic in very fast shipping.
Filip M.
Didn't expect that much of a difference. Simply amazing speaker cable, makes listening a lot more fun. It would be a good idea to get some pliers along with it, peeling the wires was a pain.
Yngve I.
Superb
If you have the means, buy !!!
Vladimir S.
Dead quiet with thrilling transparency
The first thing which I noticed having installed the cable between my Plinius 9200 integrated and Dynaudio Contour 20 was the absence of any noise between the notes. The location of instruments became absolutely precise, timbres more natural and rounded, more life-like and less digital with my all digital sources. It is only the first hours of listening but it is clear that this cable is an improvement over cables of equal or even higher price which I own. You only need to remember that the cable is heavy and thick which gives less flexibility at installation. It probably will lead to a higher length or dedicated supports. I used the cable single-wired having followed a mounting advice of an alternative supplier. It was a bit tricky but the result was amazing.
 (5)
The Neotech NES 3003 MKII loudspeaker cable has a special hybrid topology to reduce the effects of capacitance and inductance. Composed of OCC and...
