Pour ibasso dx340
Arvydas V.
A
Mohammed B.
Im Vergleich zu Mundorf...
Jose D.
DAYTON AUDIO LS10-44 10 "
DAYTON AUDIO LS10-44 10 "a subwoofer with an unbeatable price quality, quality materials used, professional features with a very good sound quality highlighting the low frequencies that make it an excellent subwoofer at a relatively low price for performance, we must highlight its low design with excellent aesthetics giving a professional sound.
Jose D.
Subwoofer Dayton Audio LS10-44 10"
jose p.
produit de bonne facture, je n ai pas trouver d equivalent en qualité ailleurs, je ne percois ni perte de puissance ni perte de qualité.
Achille m.
Stellar cable!
The best hdmi cable I ever heard, strong body, olografic and stable imaging, fantastic at a very low price
Christian D.
Tres bien
Déjà livraison très rapide, un bon point !
Ensuite pour le moment parfaitement satisfait de mon achat, à voir dans le temps...
Puissance largement suffisante, il m’apporte les basses qui manquaient et adouci les aigus fatigants de mes Triangle...;)
Je me garderais bien de faire telle ou telle comparaison avec d'autres systèmes, tant c'est subjectif et dépendant de tellement de facteurs...il me satisfait c'est l'essentiel !
Dirk H.
Potentiometershaft - coupler/connector
Useful little piece you often search for if working with long axles and
potentiometers.
Good quality.
Greetings
Dirk H., Germany
Dirk H.
Potentiometer Axis Extension Kit 300mm Ø6mm This 300mm long potentiometer extension kit is ideal for your DIY projects and assemblies, allowing you to place the potentiometer close to the circuits in order to limit the...
extension axis is good
this is a good extension to put a volume knob on the front panel and
place the potentiometer near the input on the backpanel.
Needs very good alignment to get a smooth action (you know, this is
machine building - sometimes 1/100 mm can make the difference)
Greets
Dirk H., Germany
Dirk H.
Super knob!
This is a very good made aluminum volume knob. Perfect surface,
very solid / heavy. Used this many times as a volume knob on preamps,
Headphonamps,...
Greets
Dirk H., Germany
Dirk H.
Bearing for poti-shaft
I use this in my front panels of different DIY-projects. Whenever I want
to bring the potentiometer to the backpanel (close to the inputs).
You have to align carefully this bearing, axle to the potentiometer for
a smooth action. Sometimes you have to sand / grind a little bit.
Use some minimum oil or grease and you will have a smooth feeling
when turning the volumeknob (also depends on the potentiometer!)
Greets
Dirk H., Germany
Dirk H.
Very good adapter
This is a very good adapter to try 2 single OPAmps (which often sound better - not always!) on one DIP8 socket for Dual OPAmps.
I use mine in a Headphoneamp for testing different OPAmps.
I also made 2 DIP8 - sockets on top. Didn't have problems with electrical contact
Dirk H., Germany
richard V.
Rapport qualité-prix exceptionnel
Cable d'excellente conception, très équilibré et définit, le son est détaillé sans être agressif, la scène sonore est bien étagée, les basses sont fermes. Je les ai comparé à du van den hull et de l'écosse sur système linn et teac ils sont équivalents pour un prix bien plus modique. Rapport qualité prix exceptionnel.
A lire les commentaires, je craignais une faible qualité de ces pieds ! En fait, ils sont parfait de stabilité, et, de qualité, ils sont sous une platine vinyle Thorens, en remplacement des pieds cahoutchoucs d'origines, et aucuns soucis de décollage des joints, ou autres remarques, et l'esthetisme est bon ! Je les recommande fortement....
Michel E.
Adaptateur haut de gamme
Indispensable si vous voulez "upgrader", sans déperdition, avec un cable secteur performant votre matériel doté d'une prise en trèfle. Acheté pour le DAC REGA 1ère génération. Grande qualité de fabrication.
Michel E.
Purifier votre courant...
Petit mais costaud !!! A positionner en tête de barrette ou au milieu entre les sources et les amplis. Les "rumble" et autres ronflements disparaissent comme par enchantement pour plus de silence, d'aération et de clarté dans la retranscription musicale. Loin du gadget, ce filtre actif est plus efficace et bien moins onéreux que des nettoyeurs de courant classiques qui tassent la dynamique. A conseiller pour des systèmes Hifi haut de gamme.
Lakphet T.
WONDOM ADAU1701 DSP Active Audio Crossover with RCA daughter board option
Received the package quickly and with very high quality
Eric D.
Un rapport qualité prix époustouflant. Grande transparence à tous les étages. Une grande précision, pour chaque instrument aussi bien que pour les voix. Testé avec une paire de vieilles Cotre Cabasse et des fichiers haute def. Pour un si petit budget ça déménage.
Jacques S.
NEOTECH STDCP-16 Hook-Up Wiring Multi Strands UP-OCC Copper PVC 16AWG / 1.31mm² Neotech offers high-quality STDCP wiring products using UP-OCC monocrystalline copper.
NEOTECH STDCP-16 Fil de Câblage Cuivre UP-OCC Multibrins PVC 16AWG / 1.31mm²
Excellent fil de câblage pour enceintes en interne . Très bon résultat sonore sur tout le spectre audio,raffiné et détaillé avec basses profondes et définies.
Jacques S.
DAYTON AUDIO DC28FT-8 Speaker Driver Dome Tweeter Silk 50W 8 Ohm 89dB 1300Hz - 20kHz Ø2.8cm This 28mm silk dome tweeter is strongly inspired by the prestigious Nordic solutions and provides a silky, pleasant sound and high capacity for detail. With a straight-line...
DAYTON AUDIO DC28FT-8 Haut-Parleur Tweeter à Dôme Soie 50W 8 Ohm 89dB 1300Hz - 20kHz Ø 2.8cm DAYTON AUDIO DC28FT-8 Haut-Parleur Tweeter à Dôme Soie 50W 8 Ohm 89dB 1300Hz...
Superbe tweeter en remplacement d'un TW 20 sur des enceintes B W DM5. Excellent résultat avec le changement du câblage interne ( Néotech
cuivre OCC ) + bornier de qualité ( fréquence de coupure du filtre à 2500 Hz). Les enceintes sont alimentées par un FDA Alientek D8 sous PC windows avec Foobar + Asio : aigu raffiné et étendu . Très recommandable, avec un excellent RPQ. Merci Audiophonics.
Michel D.
Hautement recommandable
Tout d'abord, 5 étoiles sans hésiter pour un RQP hors normes.
Les premières heures d'utilisation (quid d'un éventuel rodage?) permettent de confirmer les avis déjà postés: précision holographique de la scène sonore, aération peu commune, pas d'agressivité, timbres d'une très (trop??) grande douceur; la prise casque est excellente, mais il semble que l'utilisation d'un ampli dédié améliore encore les choses.
Pour ce qui est des -légères- réserves: les deux extrémités du spectre sonore sont peut être un peu "poncées".
L'utilisation via foobar sous windows10 ne pose pas de problèmes, après quelques tâtonnements.
Cerise sur ce délectable gâteau: une prestation absolument irréprochable d'Audiophonics
cedric r.
ARMATURE ELECTRA 8
Amélioration du son : Oui ! ,13,5 sur 20. (par rapport a une legrand!!!!)
Fiabilité,Robustesse : J'ai des gros doutes !!! (déja un retour en SAV !!!)
SAV Audiophonics : Très très bien !!!! Rapide!!!!, Rien a redire!!!!. ( Peut etres la prise en charge financiere du colis en retour magasin pour le sav !!!!
Pierre C.
ALLO USBRIDGE Aluminum - Audio Media player Volumio interface for USB DAC This version of the ALLO Network Drive includes the VOLUMIO software pre-installed. It is thus the easiest version of use for neophytes.
Couplé à l’alim ifi le rendu est excellent! pas mieux pour le prix : son plus clair et précis qu’avec foobar Asio sur le PC.
Mise en route de l’os Volumio accessible avec les infos à dispo sur le net; idem pour monter un répertoire du Nas et paramétrer un Dac.
stéphane P.
Ampli utilisé avec une alimentation smps600Rxe (+/-55v) et un radiateur pour fonctionner sous 4 Ohm et un potard de 50K en atténuation.
Cet ensemble alimente des enceintes Magnepan 1.6QR de faible rendement, en remplacement d'un amplificateur Marantz PM80 classe A/AB de 2x160W/4 Ohm.
Pour 20 fois moins lourd, mais avec plus de 200W disponibles sous 4 Ohm, cet amplificateur est parfaitement à l'aise et ne rugit pas devant le Marantz pourtant très bon.
Aucun bruit de fond, aucune ronflette même à fond. Le haut du spectre est clairement plus précis.
Très impressionnant au vu du prix. Je conseille fortement.
Attention, le connecteur d'alimentation est livré mais pas celui des entrées audio.
stéphane P.
Léger, chauffe assez rapidement et bien, niveau de température réglable avec petite led qui s'éteint quand c'est prêt, vraiment top à ce prix.
stéphane P.
Esthétique, lourd et solide, simple à mettre en oeuvre, au vu du prix, vous pouvez foncer sans hésiter.
Martin S.
Great Converter
My favorite DAC is a bit fussy over USB inputs and didn't work well with the Raspberry output. I was looking for a USB to SPDIF converter and came across the Hecate products. I chose the LT version after looking at some reviews.
Performance:
I am very impressed! To date I haven't really detected any very obvious sonic signature or coloration. As I was very happy with the sound and dynamics of the DAC, this pleases me as I have achieved exactly what I was hoping to. I would definitely recommend this product for anyone in a similar situation. In general I would try and avoid any in-line signal conversion, but the Hecate shows that signal conversion can be done very effectively.
Pascal S.
pangea pico
Mérite d'être connu rapport qualité prix 10/10 ; d'une efficacité redoutable
JOEL M.
rectificatif
Contrairement à ce que je viens de dire, l'USB fonctionne très bien sous linux, il fait simplement bien paramétrer l'audio.
Que de la qualité !
Je cherchais un ampli/dac intégré pour écouter Qobuz à partir de mon PC portable. C'est la bonne solution, la qualité sonore de l'ampli est vraiment bonne. Le dac convertit le flux du PC (320kbps) en 176.4 khz !
La documentation mériterait plus de détails et d'explications pour les options du menu: ASRC mode et EQ mode menu par exemple.
Michel L.
Bien, mais encore améliorable
J'avais déjà un petit ampli classe D "Fiio A1" très satisfaisant (simple et agréable à l'écoute) pour driver une paire de 10 cm fostex large-bande. En comparaison, ce petit ampli SMSL est encore moins encombrant, mais il est si léger que lorsqu'on appuie sur le switch d'alimentation, il glisse en arrière...à moins de mettre la main dessus en actionnant l'inter avec le pouce. Je préférais le potentiomètre interrupteur du Fiio, plus fonctionnel et plus simple encore. Par ailleurs, les 2 led bleues qui indiquent la mise sous tension de l'appareil sont cachées sous le bouton de volume, les rendant invisibles, même dans l'obscurité. Peut-être faudrait-il percer le bouton au niveau du repère afin de laisser passer un peu de lumière?
Pour ce qui est du son, c'est neutre, un poil brillant peut-être ou manquant de grave c'est propre, et pour le prix très abordable on peut dire qu'on ne peut qu'en être satisfait lorsqu’il s'agit de constituer une base pour un petit système d’appoint compact.
Bon rapport qualité prix. Bon contact, ferme et rassurant, double serrage sur une bonne longueur de câble dénudé.
A terminer de préférence à la gaine thermorétractable afin de garantir un minimum d'isolation en cas de maladresse.
à éviter
La "sécurité enfant" empêche de brancher quoique ce soit dans les prise, à moins de forcer en appuyant comme un malade au risque de casser ce que l'on branche!...Donc faire très très attention ou démonter et enlever les sécurités qui rendent la multiprise quasi inutilisable. Pour du matériel soit disant pro, c'est une catastrophe!
JOEL M.
Rapport Q/P excellent.
Tout y est: timbres, spatialisation, dynamique, puissance.
On entend claquer les percussions, vibrer les cordes avec une clarté confondante. Tout petit bémol (très petit) manque un peu d'espacement entre les plans en profondeur, les voix sont un peu en retrait à mon goût.
Autre bémol, mais qui n'est pas du fait de l'ampli, il ne fonctionne pas en USB relié à un PC sous linux.
Conclusion: je recommande chaudement.
Holger B.
Sélecteur de source bidirectionnel 3 cinch à 1 cinch / 1 cinch à 3 cinch avec télécommande
Cet interrupteur répond pleinement à mes attentes! Aucune perte de signal audible! Pour ce prix, il n'y a probablement pas de meilleur commutateur RCA!
Non seulement il a l'air sympa, mais il remplit également plus qu'un simple commutateur et un séparateur grâce à son utilisation bidirectionnelle!
Holger d'Allemagne
PARFAIT
Viennent remplacer des pieds cahoutchoucs usés, sur Thorens TD 145 MKII, c'est pieds sont parfait de stabilité, pas de soucis de décollage du joint comme évoqué ci-dessus, et bon diamètre...
Ce produit offre une pafaite stabilité à ma platine, et un bon aspect. A conseiller...
Gaetan I.
Ravi
Très facile d utilisation. Idéal pour se substituer à une carte son. Redonne vie à mon casque et à mes HP de monitoring.
Lucien S.
Le Topping un petit ampli pour intras.
Mon smartphone ayant une puissance d'amplification réduite j'ai acquis ce petit ampli et je dois dire qu'il donne un peu plus de volume sur les intras et molette du volume et celui de l'ampli au maximum je peux apprécier ma musique à un niveau plus réaliste cependant il ne faut pas espérer utiliser cet amplificateur de puissance modeste avec un casque dont les membranes à remuer sont plus large et quelle que soit sa sensibilité ou son impédance vous n'obtiendrez aucun résultat avec ce Topping, un ampli plus puissant est donc requis et aussi plus coûteux.
Ce petit ampli très bon marché est donc justifié sur des intras assez sensible de préférence et la qualité sonore est de mon point de vue améliorée par rapport à ce que donne celle du téléphone sortie casque.
joffrey J.
Amélioration sensible
N'ayant pas le budget pour changer de dac, je me suis tourné vers cet interface. Je ne regrette pas car l'amélioration est audible et ce dès les bas niveaux sonores. On gagne en précision et en détails. Un upgrade qui me permet de profiter de mon dac encore un peu. J'utilise un MacBook pro, cable USB wireworld rouge, l'hecate, spdif canare, dac arcam irdac, atoll in100se, monitor audio silver 6. Je recommande ce produit.
Mauro M.
AUDIO-GD R-28 2020 EDITION DAC R2R DSD Natif Amanero / Preamplifier / Headphone amplifier The R28 Audio-GD is an all-in-one unit of rare versatility that merges in a single housing a very high quality full R-2R DAC with a discreet balanced preamplifier and a high...
Audio-Gd R28 (in italien)
Servizio Audiophonics impeccabile.
Consegnato in 4 giorni dalla spedizione (in Italia).
Il Preamplificatore/DAC Audio-GD R28 credo che sia il best-buy attuale del catalogo Audio-GD.
In un contenitore compatto e non troppo pesante c'è un capolavoro di musicalità.
Ho utilizzato per un mese di recente un Master 11S e devo dire che questo non me lo fa rimpiangere.
La parte DAC è decisamente migliore del mio vecchio Audio-GD NFB 7.1 di 5 anni fa, quella pre leggermente più avanzata di quella del mio NFB1-Amp.
Kingwa non fa passare il tempo invano e continua ad evolvere la sua produzione mantenendo la stessa filosofia, fatta di buona musica anzichè misure perfette.
In futuro prenderò in considerazione solo apparecchi di fascia superiore e sempre R2R.
Grazie.
Jacques D.
Une merveille
Je viens d'acquérir récemment cet ampli. La qualité du son est quasiment sans défaut,
tout est d'une clarté limpide! Par rapport à un ampli bien plus cher, il y a comme un léger voile qui se retire.
Si les enceintes sont à la hauteur de cette ampli,
alors le concert (musique classique) entre dans votre pièce d'écoute,
et la chaîne hi-fi disparaît! ampli de très bonne facture tant sur la qualité d'écoute que sur la conception Je le recommande!
François C.
Investissement et plaisir du beau son
Apres consultation par mail de Audiophonics et lecture attentive de différents forums sur les Sparkos, j'ai investi dans 3 unités pour remplacer les Op Amp de ma carte son ASUS Xonar STX. Je précise que j'écoute ma musique aves des HIFIMAN He400i.
Bilan de cette opération.
Sur un plan purement musical je reste un peu sur ma faim. Certes on y décerne une légère amélioration dans les timbres, moins de "rondeur". Son un peu plus cristallin. Mais tout ceci reste extrêmement subjectif. J'enlève une étoile.
Le deuxième point, c'est la spatialisation et là les Sparkos font merveille! Les instruments se détachent clairement. Si vous possédez des fichiers sons de haute qualité (16-24 bits) allez-y. Pour des fichiers médiocres (mp3) laissez tomber.
luc A.
Excellents
4 HP branchés en série (par paire pour atteindre 8Ohms) et connectés à un ampli 2x80watts sur la sortie sub et vissés à mes 4 sièges cinémas: que du bonheur.Ils complètent bien les 2 subs déjà présent.Parfaits pour les films par contre je désactive pour les concerts car pas trop réaliste.
Paul K.
Item arrived fast and in well packed plastic zip bag. Cable looks strong an durable and have gold platet connectors with safe plastic caps.
Très bon amplificateur
J'avais déjà posté un avis très favorable (le 02/12/2016 - Daniel L.) à la suite d'un premier achat.
Je viens d'acheter une deuxième ampli., pour une autre installation chez moi, et je reste totalement satisfait.
Par rapport à l'ampli acheté en décembre 2016, seule la télécommande a été heureusement modifiée.
La nouvelle télécommande - qui possède les mêmes fonctions que la précédente - a l'avantage de fonctionner avec deux piles AAA (beaucoup plus pratique que l'ancienne télécommande qui était alimentée par une pile bouton, moins répandue que les piles AAA).
Je recommande cet achat.
Pascal B.
Parfait.
Potentiomètre d'origine ALPS, m'a permis de réparer mon ampli Rega Elicit. Le résultat est parfait, avec la certitude d'avoir une pièce identique à celle qui équipait mon Rega.
Un câble est un câble !!
Celui-ci remplit son rôle, c'est tout ce qu'on peut lui demander.
En bref, j'en suis satisfait.
Pas pratique
Je confirme : ce n'est pas pratique du tout.
Pas de mode d'emploi, mais je suppose que, pour les fils assez fins, on doit les enrouler autour du filetage en les passant par les trous latéraux.
Quant à moi, j'ai préféré souder (solution néanmoins moins évidente que le vissage possible sur d'autres fiches banane).
Bref, je ne recommande pas.
daniel k.
very nice
very nice quality knob!
Marc-Olivier C.
Bouton
Déçu car fragile au niveau des pins, deux pins sont cassées en les pliants pour pouvoir l'intégrer au système, il faut donc éviter de trop les manipuler et de trop les chauffer sinon elles casses.
Le côté négatif, c'est que Je dois malheureusement en racheter un autre...
Le côté positif, c'est que celui-ci est joli.
Marc-Olivier C.
Softstart
Fait parfaitement son job. Je l'utilise sur un transformateur torique de 625VA, avec une batterie de condensateur de 2 fois 10000uF par enroulement secondaire après le redressement bien sûr :) .
