Pour ibasso dx340
Arvydas V.
A
Mohammed B.
Im Vergleich zu Mundorf...
Wayne M.
evo oil
very good service, always find the team to be very helpful, my first time trying the evo oil i will use again impressed thank you
Everaldo R.
XANGSANE SP-8540 Speaker Cable Silver-Plated OFC Copper 2x4mm² This Xangsane SP-8540 is a speaker cable whose conductors are both made of 7 strands of silver-plated OFC copper for enhanced conductivity. The...
I'm very happy with this speaker cable.
I used it for my Focal Chora 816's and I have a feeling the highs are a bit more relaxed with these cables than my copper ones. But still a very clear and enjoyable sound with the xangsane sp8540 speaker cable.
Everaldo R.
Very nice plugs for the price, that fitted nicely in my Focal Chora 816's.
jean-christophe D.
AUDIOPHONICS HPA-S300NIL Power Amplifier Class D Stereo Nilai500DIY 2x300W 4 Ohm Hand-assembled in our workshop in France, the Audiophonics HPA-S300NIL power amplifier is a high-performance stereo model, based on the new Hypex Nilai500DIY amplification...
impressionnant
je viens de recevoir mon nouvel ampli made in audiophonics.
il est encore en rodage mais je dois dire que c'est "du lourd".
c'est la nouvelle version en double mono total avec deux nilai 500 et deux alim independantes.
la puissance n'a quasiment pas de limite. la definition est totale sur tout le spectre, jusqu'aux tres basses frequences.
Raccorde a mon nouveau streamer matrix (avec roon et qobuz) et aux enceintes Klipsch RF7, c'est top niveau.
bon, les RF7 montrent leurs limites et il va falloir s'occuper de cela prochainement mais pour la partie electronique, je suis pare pour un moment.
Câble qui va loin pour le prix
Câble performant et équilibré, j'aime beaucoup, une belle découverte pour pas trés cher.
Hans Klaus R.
ATAUDIO Q8RF Female RCA Connector Ø7.5mm (The pair) These gold-plated RCA connectors are designed to provide good conductivity and resist oxidation. The conductors are made of high purity copper for a very good transmission of...
Good quality, Easy soldering
made from metal, solid feel, screw thread works smooth and locks firmly. All in all high quality appearance. Easy to solder, soldering points for + and - are on same level and avoids uneven cable lengh cutting to keep them nicely parallel.
Diameter for cable outlet (7.5mm) is only ideal for strong cable diameters - for usual audio lines too spacey (hence 4 out of 5 stars). Make sure you use large diameter audio cable for perfect fit.
Eduard V.
Doet zoals beloofd werkt perfect.
Goed product simpel te installeren (misschien zou het iets sneller mogen werken)
Tom K.
TOPPING D90 III SABRE Balanced DAC 2x ES9039SPro Bluetooth 5.1 32bit 768kHz DSD512 MQA Black Topping's D90 III Sabre balanced DAC is an evolution of the Topping D90SE DAC. In this improved version, Topping has chosen new components and added new features for enhanced...
This is a quality product and the after sales service is very good
I received this DAC only two days after ordering it from the Netherlands.
The sound of this DAC is simply stellar, much better than anything I have heard before (I have heard and owned a lot of DACs inluding the D90se, Linn Akurate DS).
The bluetooth remote gave me troubles so I had to send it back. The after sales service of Audiophonics is very good and reassuring. Which is why I already ordered some other things on this site.
Also the Audiophonics website and tracking system is better than many other shops.
Makoto H.
Superb power amplifier
Firstly thank you for your quick delivery! I ordered the amplifier on Friday night and received it onTuesday noon in Japan! I’ve never experienced a delivery so quick from abroad. Also the power cable was perfect for use in Japan. Thanks again to the people who made this happen.
Secondly the amplifier’s black aluminum body looks nice with RCA connectors at the back as gold accents. So are the speaker cable connectors.
And the sound. It is clear and covers from the delicate sounds such as Miles Davis’s first phrase of The Sketches of Spain and to the wildest bass in Sonny Rollins’s Night at the Village Vanguard with quite ease.
Actually it can reproduce any music, including classical, I throw at it comfortably and without any difficulty. It seems it can drive my speaker to its limit.
The amplifier is superb!
Didier C.
TONEWINNER AT-300 EXT 5.1 AV Processor / Home-Theater Preamplifier Dolby Atmos 16 Channels 9.3.4 / 7.3.6 The Tonewinner AT-300 is a 16 channel audio/video processor and preamplifier, ideal for home theater integration in 9.3.4 or 7.3.6 configurations. It supports all current audio...
Préampli HC ToneWinnet AT-300
Super. En service depuis deux semaines, l'image est sublime et le son également. Je ne l'utilise qu'en HC et 3.1. Même si l'interface peut paraitre dépassée, tout y est et de toute façon, une fois réglé on y revient dessus que très rarement. Rapport qualité prix imbattable.
Qualité du service et emballage toujours au top.
Merci Audiophonics
Cable neutre et transparent mais pas ennuyant à l'écoute , se bonifie avec le rodage et acquiert un très bon équilibre . On entends tous les détails sans agressivité ; timbres respectés . Le rqp est excellent . je serai curieux de le comparer au NFS 6 son grand frère vu la qualité de cette entrée de gamme ?
ERIC C.
Bien pratiques !!!
Utilisé entre ampli un Marantz SR8015 qui possède 2 sorties trigger et 2 amplis Nuprime STA9 n'en ayant pas, ces petits boitiers qui sont équipés de prises 12v font le boulot et alimentent mes nuprimes à la mise sous tension ou arrêt du Marantz, il a fallut créer 2 petites rallonges car les boitiers branchés sur les nuprimes sont en position verticale avec la prise 12v dirigée vers le bas et vue la faible hauteur des nuprimes cela posait problème d’où la petite rallonge entre ampli et boitier.
RENAUD C.
Câble de modulation fin et souple. Très bon rapport qualité/prix
RENAUD C.
Une 12AT7 recommandée
Un bon tube, équilibré, bien construit, très satisfaisant pour restaurer mon petit ampli Jolida JD 202.
RENAUD C.
Professionnel et fiable. Grande qualité pour un prix raisonnable.
RENAUD C.
Professionnel et fiable. Grande qualité pour un prix très raisonnable.
Excellent rqp
Il est préférable de lui connecter des prises sans argent car il propose beaucoup de détails, une belle séparation des instruments et une stéréo superbe.
Idéal pour les dac et ampli classe d.
Bon cable
Utilisé avec un dac préampli, il est a sa place.
Spzcialisation, scène sonore large et bien défini. Détail mais reste plus chaud que je l' aurai pensé, d' après les commentaires. Je recommande
montage impossible
Cette prise est un test de zénitude, si vous ne sortez pas de juron vous réussissez le test.
Quand on réussi avec beaucoup d'effort à connecter ses câbles , la galère n'est pas terminée, il faut maintenant fermer le couvercle.
Pas de bol ça ne ferme pas car les vis des borniers tapent dans le capot , sauf si vous avez mis du fil de 0.5mm :)
Je n'ai pas réussi le test :)
Lancelot B.
Très bon amplificateur
Il remplit parfaitement le job, tout en délivrant une grosse puissance, pour un prix avantageux. Superbe !
Marcel O.
insanely high quality built product, top notch
An absolut fantastic DAC. I love the reproduction of voices, very natural and holografic. One can easily trust the positive reviews on youtube without a doubt. Finally my Pioneer TAD S-3ex front speaker play the music at their best. I am very pleased to highly recommend this product based on my experience.
Dimitri R.
M'a permis de ressortir mon vieux Pi3 pour le transformer en Spotify Connect via Moode Audio (Audiophonics 9023 directement dans la liste des i2s).
Le son est nickel connecté à mon ampli.
Testé sur Picore Player et Volumio, reconnu en selectionnant i2s-DAC. Moode est celui qui réponds a mon besoin avec ce matériel !
Envoi rapide de la part d'Audiophonics, rien à dire comme d'hab !
jean-pierre R.
Phono Preamplifier Board Low Noise OPA JRC5532 This phono preamplifier module benefits from a nice design, using two JRC5532 AOPs mounted on DIP8. It is also equipped with two Nover 35V filtering capacitors of 4700µF...
Idéal pour rénover une vielle platine
Acheté pour "électronifier" ma vielle platine Thorens et choisi pour l'intégration de sa propre alimentation, ce module a pu être logé sous le chassis et a donné entière satisfaction. J'en ai profité pour ajouter une embase secteur IEC et des embases RCA, le tout disponible sur le site audiophonics. Un petit bémol : la position des entrées / sorties RCA qui ne facilite pas la soudure des câbles de modulation.
Merci encore audiophonics pour la rapidité des réponses à mes demandes de précisions.
Hasni Z.
Top qualité.
Bonne épaisseur et résistance une fois réduit.
Bon sèche-cheveux indispensable (merci madame :)
Hasni Z.
VIABLUE Braided Sleeve Blue 13-26mm The diameter of these ducts can be adjusted by 13-26mm. It is possible to overlay 2 layers of braided sleeve, so your cable is even better protected.
Bon rendu final
Pour un câble de 1,90 m, j’ai commandé 2 mètres mais c’était trop juste… solution : j’ai dû réduire la taille du câble à 1,80m + gaine thermo et là c’est nickel !
Hasni Z.
[GRADE S] ELECAUDIO CS-361B Power Cable OCC PTFE 3x2.5mm² Double shielding Ø17mm 1.9m Refurbished product - Grade S 1.9m long pre-cut cable
Excellente qualité de fabrication.
Tout juste monté sans difficulté et un tuto existe sur ce site.
En rodage avec le câble qui va bien sur un Heed Lagrange S.
Hasni Z.
Tout juste montée sans difficulté et un tuto existe sur ce site.
Hasni Z.
Efficace et simple montage
Hasni Z.
Bonne qualité / finition
Produit bien mieux fini que sur les photos de présentation !
Ça respire la solidité.
Edmond P.
Pour mon Raspberry Pi zero 2W je voulais un DAC usb qui ne soit pas énorme et c'est parfait.
J'ai juste ajouter un petit adaptateur micro usb male/usb-c femelle pour faire le job.
Seul petit bémol la puissance de sortie audio est un petit peu faible mais je peux compenser largement avec mon ampli.
La qualité audio est aussi bonne que celle de mon DAC Sabre SA9023.
Rajiv J.
Good preamp for the Gustard R26 DAC
I was looking for a preamp for my Gustard R26 dac, and was torn between the H26 and P26.
I chose the P26 preamp based on some (really helpful) advice from the Gustard support. The choice was driven by the following aspects:
1) I did not need the headphone amp, just a pure preamplifier.
2) I have swapped the LME49860 op amps on the P26 with Sparkos Labs SS2590. The Sparkos pair cost me 250 Euros, which took the P26 to a whole new sound level, that is hard to describe. The LME49720 op amps on the H26 are also on swappable DIP8 switches. However it has capacitors mounted very close to the Op-amps, and the Sparkos OpAmps are big and need space (LxB is 1.1 x 1.1 inch, or 2.8 x 2.8 cm). Gustard was kind enough to send me close up measurements that helped me conclude that the op amp swap would be tricky, or just not possible.
3) The P26 allows you to adjust gain between 0 to +6dB both in the input and output stage, which helps to harmonise and match with components on both ends. The H26 only has +6dB gain option at the output side.
4) Gustard support responded to my question of how both would compare in pre-amp mode with the following reply, I quote: "The P26 is a good choice for a preamp only. The P26 and H26 preamplifiers have different styles, the H26 is tuned a little softer while the P26 is a little clearer & transparent."
All in all, a good choice, as I said..
Ole B.
Keeps everything promised
Ole B.
DAYTON AUDIO RST28F-4 Speaker Driver Dome Tweeter Fabric 80W 4 Ohm 94dB 1400Hz - 20kHz Ø2.8cm The Dayton Audio RST28F-4 tweeter with fabric cone offers excellent performance, allowing frequencies from 1400Hz to 20kHz to be reproduced with both natural and dynamic sound.
The best tweeter I've had. Much better than others much more expensive
Mikhail M.
Bien!
Super amplificateur. Un amplificateur de classe AB à 2000 euros, d'une marque réputée, a été vendu. Fosi ne lui était pas inférieur en qualité.
p.s. La qualité des basses dépend en grande partie de la qualité des enceintes et de leur connexion avec la pièce. La classe D gère très bien les basses.
pascal P.
Testé avec deux autres de sa catégorie, c'est celui que j'ai gardé. Très ouvert, très neutre, très dynamique mais pas "numérique". Un grave incroyable vu la taille. Il vaudrait plusieurs fois son prix si c'était une grande marque traditionnelle.
pascal P.
Pas si bien
Après les nombreux commentaires élogieux je m'attendais à mieux. Cet ampli est assez brouillon, les basses en retrait, un son de type numérique. Il est correct pour son prix, mais rien de miraculeux.
Klaus B.
A cheap way to improve your PSU
I use this module in combination with a "Power supply module Dual DC LM317 T 12V 1.5A (Ref. 8424)"as an external PSU for an USB-Card. After installing the Ultracapacitor Module we could hear more details and the musicians were better to localise. Very nice!
I don´t give this module 5 stars because I tested the IAN CANADA UCCONDITIONER and it is even better. But it is more expensive too. So the Ultracapacitor Module really is quite a good choice if You don´t want to spent the money for the IAN CANADA module.
benjamin b.
Installé sur un petit système vintage, ampli Sansui et enceintes B&W dm4, le résultat est au rendez-vous. C'est équilibré doux et précis. Les basses, naturellement en retrait sur ce genre de petit matériel, reprennent leur place, et son bien tenues.
Je valide complétement. Attention au diamètre du câble souvent délicat à brancher aux borniers des vieux amplis qui étaient toujours sous dimensionnés.
Andrea T.
USB 5V Supercapacitor Filter USB-C to USB-C / USB-A This 5V USB filter allows you to obtain a clean power supply for your Hi-Fi devices thanks to two 20F - 3.0V capacitors as well as an intelligent buffer...
Good improvement
Placed between an iFi iPower 5v and a Topping 30 II, it improves clarity and detail.
It won't have the performance of expensive linear power supplies but it holds up well.
Recommended
SERGE B.
Bon rapport qualité/prix
Bon rapport qualité/prix mais attention, l'extensibilité m'a semblé moindre que celle indiquée
SERGE B.
Expandable Braided Nylon Sleeve 6-12mm Gray This grey braided nylon sheath will effectively cover your cables and give them greater mechanical resistance. This has an adjustable diameter from 6mm to 12mm.
Bon rapport qualité/prix même si un peu fragile.
Bonne capacité d'extension mais s'effiloche très facilement ! Je conseille de mettre un scotch à l'extrémité libre pendant la mise en place et le raccordement du câble gainé. On peut laisser celui-ci en place s'il est recouvert ensuite sinon, il vaut mieux un peu de colle cyanoacrylique
Talmadge I.
Sweet Spot of Class D Power Amplification
I bought this power amplifier to run a pair of difficult to drive but well loved Infinity Kappa 9's. It handles them with aplomb. Zero background noise, a common complaint on prior Class D amplifiers. For 700 Euros shipped, it is a bargain if you don't want to build yourself. The Purifi based amplifiers may put up slightly better specifications, but in my room I can't ask for more than this amplifier deliveres for the price.
Henry C.
Sounds thin so far
I’ve got to say after almost 23hrs in my system the little Aiyima DAC A3 at a price one fifth what I paid for this and only .775 volts per channel of output at the RCA’s sounds much stronger than this one with 2.1volts at the RCA’s per channel. I hope with more time it begins to sound more full bodied on the low end but right now I’m a little disappointed in what was supposed to be something much better than what I had. Maybe that changes with more break in. I hope I does because the two Audiophonics 200 watt purifi amps combined with the Topping Pre 90 preamplifier with the little Aiyima DAC A3 was sounding great! Couldn’t be more satisfied with my other purchases. Crossing my fingers for now.
SERGE B.
ELECAUDIO CH-22G MK2 Power Connector Switzerland SEV 1011 24k Gold Plated Ø17mm This Elecaudio CH-22G MK2 connector is a Swiss J-type mains connector (SEV1011). It features an insertion ring limiting the cable diameter to Ø17mm, as well as an...
Excellente qualité
Très belle fabrication. En remplacement d'une prise assez basique sur un câble d'alimentation "audiophile" d'une marque anglaise réputée pour branchement d'un ampli à lampe à un autotransformateur. Excellent résultat après blindage du câble en question avec disparition des bruits de basse fréquence.
SERGE B.
Très efficace
Utilisé pour blinder un cable d'alimentation "audiophile" d'une marque anglaise réputée à un ampli à lampes. Le bruit de fond de basse fréquence a totalement disparu. En connectant le blindage à la masse aux deux extrémités évidemment...
On lit tout et son contraire à ce sujet mais dans ce cas ce fût concluant.
Gilles S.
Nouvelle vie pour un vieux Yamaha YST-SW50
Possédant un caisson Yamaha subwoofer actif qui a un peu plus de 3 décennies encore fabriqué au Japon à l'époque a récemment perdu la suspension de son haut-parleur. Donc que faire ? Il y a plus de dix ans j'avais acheté un kit subwoofer atohm rafale 38 qui fonctionne toujours à merveille chez audiophonics et très content qu'ils existent toujours... Voilà comment j'ai trouvé ce petit HP ÉPIQUE de Dayton Audio qui remplace depuis peu le HP Yamaha d'origine et je dois dire que le résultat est vraiment terrible ! Je redécouvre mon caisson basse. Très très heureux et merci audiophonics d'être toujours là.
Raphaël B.
Très bon produit, excellent rapport qualité prix
Belle facture, les tensions et courants demandés sont respectés. c'est la deuxième fois que je fais appel à ce service et j'en suis très satisfait.
Raphaël
Filip B.
Should be like must
I purcese it with DC purifier and work for me just great. I sould do this before. Recommendet.
Filip B.
Should be like must
I had quite some problems with USB conection from streamer to DAC, after I purchace this tweek I have no problems any more.
For shure it helps, also for sound, everything is more clear.
Filip B.
Should be like must
This realy works, you can even hear the difference on medium good equipement. I have it for router used for streaming.
