IAN CANADA IVSTD MKII Output stage module for DAC ES9038Q2M - ES9028Q2M
I/V STD standard OPA I/V output board
The IVSTD MKII module at Ian Canada is one of the rare balanced and unbalanced output modules that can be used in a pure DIY approach.
Reference : 13977
49,90 €tax incl.
41,58 € tax excl.
Shipping date: 26-04-2024.
Shipping from France
Billing in France
Technical support in France
Ian Canada IVSTD MKII
Output stage module with 3x removable OPA
Output Module Audio High Fidelity Hifi Ian Canada
It is designed to immediately adapt to Ian Canada's Raspberry Pi-based digital to analog conversion solutions (such as ES9038Q2M & ES9038Q2M Dual Mono).
Moreover, the IVSTD output module is constructed so as to fit a wide range of construction / development projects. It is not exclusive to the world of RPI & SBC.
Balanced and unbalanced analog audio output
The module has an unbalanced output on stereo RCA connector and a balanced output slot for XLR stereo connectors.
Please note, XLR connectors are not supplied with the kit : tose use the balanced output, you have to order and mount them yourself on the PCB.
When combined to a compatible DAC, the conveter / output stage becomes a powerful whole that can attack a wide range of preamplifiers (or integrated amplifiers). Balanced and unbalanced outputs enables it to join advanced Hi-Fi installations as well as smaller or more exotic audio systems.
Finally, the card has a high-level headphone output on 3.5mm stereo jack. To avoid noise polution, the headphone circuit is independent from the left and right lines of balanced and unbalanced audio outputs.
Three removable operational amplifiers
The card uses three operational amplifiers mounted on DIP-8 support. Audiophiles can change them on the fly to find the sound signature that best matches the overall flavor of their audio equipment.
On reception, three JRC 2114D are mounted on the board. This model is a high performance & low noise stereo OPA. It may be replaced by any models supporting + 12 / -12 VDC voltage.
Two of these OPA are used for driving the left and right channels of the balanced and unbalanced outputs. The third component is in charge of controlling the headphone output.
IVSTD pcb dimensions
Caution : only the output stage is delivered with this product. The Raspberry Pi Board, the ESSC Controller and the ES9038Q2MPI must be bought separately.
Schematic dimensions & spacings
IVSTD dimensions and spacings
Technical caracteristics
TypeOutput stage module
Power supply+12 VDC
-12 VDC
+ Location for DC / DC converter
Operational amplifiersx3
Removable (DIP8)
Pin-CompatibleES9038Q2MPI Dual Mono
ES9028Q2MPI
Dimensions85 x 55mm
Distances+ 23.5 mm 81.5mm / 58mm
49 mm
InputNC
OutputJack 3.5mm
OutputSolder pad
Bon produit
Ne réponds toujours pas non plus à mon besoin mais ce module est bien conçu et de très bonne qualité/performance. Seul le signal Asymétrique est recomposé via l'inversion du point froid.
This review has been posted for IAN CANADA IVSTD MKII Output stage module for DAC ES9038Q2M - ES9028Q2M
