ETI Bulletplug Classic RCA Tellurium Copper Ø9.2mm (Set x4)
ETI Bulletplug Classic RCA Cuivre Tellurium Ø 9.2mm (Set x4)
Reference : 6776
79,50 €tax incl.
66,25 € tax excl.
Shipping from France
Billing in France
Technical support in France
The ETI Bulletplug® RCA connectors offer unlike most of their competitors, even those marketed as high-end significantly increased conductivity.
The vast majority of RCA connectors are made from nickel, golden brass or bronze / phosphorus alloy with a conductivity typically less than 28% IACS (International Annealed Copper Standard). By way of comparison, the high purity copper used in the vast majority of interconnecting cables has a conductivity rating of 100% IACS. Due to this low conductivity and the use of three disparate metals, the majority of standard RCAs, even expensive tend to decrease the performance of the components to which they connect.
The approachof ETI is radically different, the contact elements are machined in high-purity Copper Telurium (more than 90% IACS) or pure silver (106% IACS) so as to ensure maximum conductivity to 320%).
Thecontact point at one point of the mass also avoids eddy currents (href = "http://en.wikipedia.org/wiki/Eddy_current" target = "_ blank">Eddy Current).
Features:/ Strong>
  • Packing: 2 pairs
  • Contact Material: Copper Tellurium
  • 24k Gold plating directly applied to copper (no nickel, bronze or brass)
  • Connector Body: Plastic
  • diammaximum acceptable cable length: 9.25 mm ( Reducers available separately )
  • Overall length: 37.5 mm
PDF Manufacturer
https://www.audiophonics.fr/images2/6776/6776_ETIBULLETPLUGCLASSIC_2.jpg
Detail of contact elements
Max cable diameter (mm)9.0
Mounting typeTo weld
ConnecticMale
4 reviews
Très bonne fiche RCA. Montés avec des câbles argent/or Mundorf SGW 105 isolés avec de la gaine PTFE donne un son doux, sans agressivité, avec beaucoup de détails précis et une plus grande image sonore. Les instruments, les voix sont bien placés et beaucoup plus _vrais_ . Je recommande ces fiches ainsi que ce montage de câble argent/or
This review has been posted for ETI Bulletplug Classic RCA Tellurium Copper Ø9.2mm (Set x4)
le top en fiche rca que dire de plus ,très naturel et ne triche pas à rapport à certaines defois bien plus chère.........Du grand professionel
Ces prises rca sont exceptionnel de neutralité ,vitesse et sens du rytmes ,attention toutefois elles sont très fragile et certainement les meilleurs de leur catègorie.
Excellentes fiches RCA de Mr EICHMANN, certes un peu cher mais très bien fabriquées, bon contacts et le neutralité du tout cuivre
