ETI KRYO Connecteurs RCA Cuivre Tellurium Plaqué Argent Ø15 x 51mm (Set x4)
These ETI Kryos are high-end RCA connectors designed with exceptional components. It features a Tellurium Copper conductor with Silver plating for maximum conductivity and durability.
Reference : 12789
195,00 €tax incl.
162,50 € tax excl.
Shipping date: 19-04-2024.
Shipping from France
Billing in France
Technical support in France
RCA Connectors ETI KRYO
Silver plated Tellurium Copper ⌀15x51mm (Set x4)
ETI KRYO RCA Cuivre Tellurium Plaqué Argent
For the connector body, ETI uses Brass, this structure reduces vibrations but also repels EMI / RF interference.
Finally, the connector receives cryogenic treatment in the USA, giving it even higher performance.
ETI also integrates BulletPlug technology into this connector. This, rather than scattering the electrons over the entire surface of the mass ring will concentrate them on a smaller surface thanks to the second pin integrated in the connector. This results in a signal with less distortion and cleaner.
Conductor materialTellurium Copper
PlatingSilver
Housing materialBrass
Max length55mm
Max diameter17mm
Connection typeTo solder
Max cable diameter11.5mm
Package2x RCA connectors with red rings
2x RCA connectors with white rings
Max cable diameter (mm)11.5
Mounting typeTo weld
ConnecticMale
Contacts Material (Connector)Tellurium Copper
These ETI Kryos are high-end RCA connectors designed with exceptional components. It features a Tellurium Copper conductor with Silver plating for...
