VR109 RCA connectors Viborg with Silver / Gold plated pure copper conductor. This model benefits from copper great conductivity which is long-lasting in time thanks to its gold-plating.
The outer shell is constructed from an aluminum and alloys in order to take advantage of a light structure, strong and durable. The VR109 can be connected to mass wirings without placing an excessive pressure to the female connector.
Connector's isolation is made of PTFE which is an efficient protection against thermal stresses, corrosion, humidity. This allows the connector to keep its electrical properties for a long time.
Type | RCA connector |
Kind | Male |
Driver | Pure copper |
Plating | Silver / Gold |
Shell | Aluminum alloy |
Insulation | PTFE (white) |
max cable diameter | 9.5mm |
Dimensions | 13.9φ x 14.4mm x 51.5 mm |
Connection | Solder |
Package Contents | |
red connectors | x2 |
black connectors | x2 |
Max cable diameter (mm) | 9.5 |
Mounting type | To weld |
Connectic | Male |
Contacts Material (Connector) | Copper |
Contacts Plating (Connector) | Silver |
Contacts Plating (Connector) | Gold |
