WBT-0114Cu RCA Connectors Nextgen Copper 75 Ohms Ø9mm (Set x4)
WBT-0114Cu Connecteurs RCA Nextgen Cuivre (x4)
RCA WBT-0114Cu connectors enable the design of high-end finished cables through a high quality design optimized for performance. The contacts are made of pure copper with a high conductivity level for optimal signal transmission.
Reference : 8646
159,00 €tax incl.
132,50 € tax excl.
Shipping date: 26-04-2024.
Shipping from France
Billing in France
Technical support in France
WBT-0114Cu
WBT-0114Cu Connecteurs RCA Nextgen Cuivre 75Ω Ø9mm (Set x4)
RCA WBT-0114Cu connectors enable the design of high-end finished cables through a high quality design optimized for performance. The contacts are made of pure copper with a high conductivity level for optimal signal transmission. Contacts with several lamellae are machined by high-precision machines with diamond drill bits. This design allows for high contact pressure to maximize conductivity.
The connector body is made of copper alloy and the dielectric elements of Ultramid, a particularly resistant plastic. They are able to accommodate cables with a maximum diameter of Ø9mm.
Diagram
1Brass cap
2Ultramid holding unit
3Brass Torx M4x4 screw
4Ultramid plus contact dielectric
5Pure Copper plus contact
6Brass shaft of clamping barrel
7Brass head of clamping barrel
8Pure copper minus contact
9Vectra S135 minus contact dielectric
Product typeMale RCA connectors
Max cable diameterØ9mm
Mounting typeTo solder
Contacts materialPure copper
+ Contact dielectric materialGlass fiber reinforced Ultramid
- Contact dielectric materialVectra S135
Body, cap and screw materialCopper alloy
Contacts support materialFiber Glass reinforced Polyamide 6.6
Contacts platingGold 0.5µm
Permanent currentId > 10A
Transition resistanceRü < 0.1mΩ
Contact resistanceRbi, Rba < 0.1mΩ
CapacitanceC ≅ 2.5pF
Insulation resistanceRia, Rag > 1010Ω (conductor/conductor, conductor/chassis)
ImpedanceZ = 75Ω up to 200MHz
Total dimensionsØ13.6 x 51mm
QuantitySold per 4 (2 connectors with white marking, 2 connectors with red marking)
Max cable diameter (mm)9.0
Mounting typeTo weld
ConnecticMale
A recommander
Prise de très bonne qualité
Facile à souder avec soudure de même marque
Très bon son
A recommander sans réserve
This review has been posted for WBT-0114Cu RCA Connectors Nextgen Copper 75 Ohms Ø9mm (Set x4)
RCA WBT-0114Cu connectors enable the design of high-end finished cables through a high quality design optimized for performance. The contacts are...
