YARBO RCA-019GB Gold 24k Plated RCA Connectors PTFE Ø7mm (Pair)
YARBO RCA-019GB Gold 24k Plated Copper RCA Connectors PTFE Ø7mm (Pair)
The RCA Yarbo RCA-019GB connectors are models that benefit from a high quality manufacturing process. In a robust metal body are integrated 24k gold plated contacts, ensuring very good audio signal conductivity and oxidation resistance for greater durability.
Reference : 13721
39,90 €tax incl.
33,25 € tax excl.
Shipping date: 23-04-2024.
Shipping from France
Billing in France
Technical support in France
Yarbo RCA-019GB
Yarbo RCA-19GB Connecteurs RCA Plaqué Or 24k PTFE Ø7mm (La paire)
The RCA Yarbo RCA-019GB connectors are models that benefit from a high quality manufacturing process. In a robust metal body are integrated 24k gold plated contacts, ensuring very good audio signal conductivity and oxidation resistance for greater durability. The connector has PTFE isolation to reduce interference that could affect the signal and therefore the audio output. RCA-019GB can accept cables up to 7mm in diameter.
Yarbo RCA-019GB Connecteurs RCA Plaqués Or 24k PTFE Ø7mm (La Paire)
Product typeRCA Connectors
Conductors platingGold 24k
Max cable diameter7mm
Connection typeTo solder
InsulationPTFE
Totals dimensions54.1 x 14.2mm
QuantitySold per pair (1x red marked connector, 1x white marked connector)
Max cable diameter (mm)7.0
Mounting typeTo weld
ConnecticMale
The RCA Yarbo RCA-019GB connectors are models that benefit from a high quality manufacturing process. In a robust metal body are integrated 24k...
