Gold 24k Plated RCA Connectors PTFE Ø7mm (Pair)
The RCA Yarbo RCA-019GB connectors are models that benefit from a high quality manufacturing process. In a robust metal body are integrated 24k gold plated contacts, ensuring very good audio signal conductivity and oxidation resistance for greater durability. The connector has PTFE isolation to reduce interference that could affect the signal and therefore the audio output. RCA-019GB can accept cables up to 7mm in diameter.
Product type | RCA Connectors |
Conductors plating | Gold 24k |
Max cable diameter | 7mm |
Connection type | To solder |
Insulation | PTFE |
Color | Black |
Totals dimensions | 54.1 x 14.2mm |
Quantity | Sold per pair (1x red marked connector, 1x white marked connector) |
Max cable diameter (mm) | 7.0 |
Mounting type | To weld |
Connectic | Male |
Contacts Material (Connector) | Copper Alloy |
Contacts Plating (Connector) | Gold |
