FURUTECH FT-903 (R) RCA inlet Rhodium plated Pure Copper (Pair)
4.2 / 5
Reference : 11703
69,90 €tax incl.
58,25 € tax excl.
Shipping date: 02-04-2024.
Shipping from France
Billing in France
Technical support in France
These Furutech FT-903 (R) solid-copper and Rhodium plated base plates offer a record level of conductivity and a flawless signal transmission.
The vast majority of audio connectorsare manufactured from brass or bronze / phosphorus alloys with a conductivity typically less than 28% IACS (International Annealed Copper Standard).
By way of comparison, the high purity copper (OFC) used in most interconnecting cables has a conductivity of 100% IACS.
Due to the use of these "low" conductivity alloys, the majority of even costly RCA sockets tend to decrease the performance off = "http://www.audiophonics.com/en/cable-et-cordon-c-1327.html" target = "_ blank">cable to which they connect.
These FT-903 (R) sockets are the result of the meticulous engineering of Furutech, with particular attention to the materials and components used.
Main Features :
  • Contacts of pure copper cut in the mass
  • Treatment Alpha a (Furutech Technology)
  • Rhodium Plating
  • Liquid Crystal Polymer resin body insulation
  • Specified for diameters up to Ø4.5mm
  • Max Connector Diameter: 16mm
  • Overall length: 40mm
  • Sold in pairs: one red and one black
  • Welding
Mounting typeTo weld
Max panel thickness (mm)3.5
5 reviews
Great buy
I used these RCA sockets in my tube DAC. Their quality is fantastic and since I haven't compared them to other sockets directly... The overall sound of a DAC is top notch.
This review has been posted for FURUTECH FT-903 (R) RCA inlet Rhodium plated Pure Copper (Pair)
Initially good, but sensitive and now broken
RCA inlet looks like a high quality, but the plug itself is made out of a thin folded sheet. When pushing an RCA plug in it under an angle, first the plastic insert breaks and then also the ring ruptures open. Had to take them out again, completely broken. So it is very important to push the RCA plug completely straight into the RCA inlet.
Super rca
Facile a installer, bien isolees, excellente connectivite.
DAC GOLDMUND
En remplacement numérique et analogique sur un dac Goldmund très haut de gamme : on passe à la vitesse supérieure sur tout les paramètres. Un vrai plus en supplément de remplacement des condensateurs audio ds ce dac!!!
Bell embase, très bien fini.
D'un prix moins élevé que les WBT, Furutech semble également travailler sur l'aspect courants de Foucault, en faisant le corps en plastique et un minimum de métal. Je serai curieux de voir s'ils arrivent au même niveau.
