1m long pre-cut cable
Refurbished product - Grade S
Brand new product. Length: 1m.
Coaxial Cable 75 Ohm OFC Copper Armored Ø6,7mm 1m
With its expertise in the realization of customized Audio / Video cables, ELECAUDIO has imagined a 75 Ohm certified Coaxial cable capable of upsetting the established order as it uses materials and technologies usually reserved for products with very high prices, even inaccessible.
This OMEGA 75 Coaxial cable in OFC Copper is intended for the High Fidelity lovers willing to upgrade their HiFi installation. It will be an excellent cable for DIY design of 75 Ohm certified audiophile cables, especially since a braided jacket is already applied on it for protection against external parasites and interferences.
Flexible and robust at the same time, this cable is composed of OFC copper conductors with PE insulation. The particular braiding of this cable allows a real insulation without the use of a sheath or a metallic strip which can raise the capacitive load and be harmful in the harmonics.
Product type | Coaxial cable |
Length | 1m |
Conductor material | OFC Copper |
Section | 0.326mm² (22AWG) |
Conductor resistance | 54.3Ω/km |
Static capacity | 69pF |
Insulation | PE |
Insulation diameter | Ø3.8mm |
Covering sheath | Nylon tressé |
Cable diameter | Ø6.7mm |
Color | Black |
Length (m) | 1.0 |
Number of conductors | 2 |
Insulation material | PE |
Shielding | Yes |
Section (mm²) | 0.32 |
Conductors material (Cable) | Copper |
Refurbished Grade | Grade S |
