Refurbished product - Grade S
Cable drop of 90cm length.
Silver Plated UP-OCC Copper Power Cable 5.26mm²
Neotech's NEP range consists of high-end power cables using only UP-OCC copper conductors of extreme purity, with silver plating. The NEP-3001 III is therefore no exception with 3 copper UP-OCC silver plated conductors with a 10AWG (5.26mm²) section. The insulation and shielding of the cable is made with PVC CL3, then an aluminium foil and finally braided OFC copper. These 3 layers make it possible to limit very largely the interferences which could degrade the signal and thus the sound restitution.
This cable sold by the metre will therefore allow you to design very high quality power cables, also perfectly adapted to carry high currents for demanding HiFi systems. In addition, the excellent transmission quality of the electrical signal allowed by these cables makes it possible to offer a very beautiful sound restitution by gaining in dynamics.
Product type | Power cable |
Conductors number | 3 |
Conductors material | UP-OCC Copper |
Conductors section | 10AWG (5.26mm²) |
External diamater | Ø 16mm |
Conductors plating | Silver |
Insulation / Shielding | PVC CL3 + Aluminium Foil + Braided OFC Copper |
External sheath | PVC |
External diameter | 14.5mm |
Cable color | Black |
Length | 90cm |
Length (m) | 0.9 |
Plating | Silver |
Separated conductors | Yes |
Number of conductors | 3 |
Insulation material | PVC |
Shielding | Yes |
Section (mm²) | 5.26 |
Connector | N/A |
Conductors material (Cable) | Copper |
Refurbished Grade | Grade S |
