By buying this product you get 64 loyalty points
Refurbished product - Grade A
Very slight wear of the OLED screen. Perfectly functional product.
Balanced DAC Headphone Amplifier ES9038Pro Bluetooth 5.0 aptX HD LDAC 32bit 768kHz DSD512
The Topping DX7 Pro is a model of versatility and performance. This DAC embeds a particularly complete connectivity, covering the vast majority of possible integrations in a HiFi audio system, combined with an intelligent architecture supporting high sampling rates and offering rich and accurate audio reproduction.
The Topping DX7 Pro betters the DAC performance of all the produces Topping had produced. On SINAD measurement, it lands in the coveted range of near 120 dB, proving beyond a shadow of doubt that it is transparent to any content you attempt to play. This is a super challenging bar to reach and I congratulate Topping for getting there.
A major difference between the DX7s Topping and the DX7 Pro, the DAC now includes an ES9038Pro ESS chip, which is more powerful than the ES9038Q2M duo of the DX7s. This new chip offers a better signal-to-noise ratio and a lower level of distortion for an ever more accurate, rich and faithful sound reproduction. In addition, this chip supports high sampling rates.
On the USB interface side, we find once again the XMOS XU208 chip, well known to audiophiles and offering an exceptionally transparent reproduction.
Also new in this Pro version of the DX7 Topping, it is now equipped with a Bluetooth 5..0 Qualcomm CSR8675 chip. While this type of connectivity is particularly convenient by offering the possibility of remote transmission directly from a smartphone or tablet, it is also synonymous with audio quality since this chip supports the aptX, aptX LL, aptX HD and LDAC protocols. These protocols allow a faster, more stable signal transmission but also, especially in the case of LDAC, to support higher sampling rates since this protocol is able to decode PCM streams up to 24bit 96kHz (24bit 48kHz for aptX HD).
For its connectivity, the DX7 Pro offers a particularly complete panel. The rear panel reveals the input of USB-B (XMOS), I2S Optics, Coaxial, I2S, AES/EBU and Bluetooth antenna. On the output side, the DX7 Pro offers balanced XLR, single-ended RCA on its rear panel. The front panel of the unit features the headphone outputs amplified with 6.35mm jack, 4.4mm balanced jack and 4 pin XLR balanced jack.
The DX7 Pro's circuits have been designed to be full balanced. Thus, the analog section includes separate OPA 1612 operational amplifiers for each channel and the headphone amplification of each channel is assigned to an independent TPA6120A2 chip.
The DX7 Pro Topping provides optimal headphone output performance with two TPA6112A2 amplifiers. Thus, in addition to supporting up to DSD1024 and PCM 32bit 768kHz, it benefits from a particularly neat analog output stage that can drive a very large majority of audiophile headphones, on 4 pin balanced XLR output.
This allows the DX7 Pro to offer a lower sound colouring and therefore a more accurate reproduction, a very low distortion and a high linearity. You gain in dynamics, detail and neutrality.
Product type | DAC Headphone amplifier |
Inputs | 1x USB-B 1x Optical 1x Coaxial 1x I2S HDMI 1x AES/EBU Bluetooth |
Outputs | 1x Balanced XLR 1x Single-ended stereo RCA 1x Jack 6.35mm single-ended headphone output 1x Jack 4.4mm balanced headphone output 1x XLR 4 pins balanced headphone output |
DAC Chip | ES9038Pro |
Supported sampling rate | USB : PCM up to 32bit 768kHz, Native DSD up to DSD512, DSD DoP up to DSD256 I2S : PCM up to 32bit 768kHz, Native DSD up to DSD1024, DSD DoP up to DSD256 Optical / Coaxial / AES : PCM up to 24bit 192kHz, DSD DoP up to DSD64 |
Bluetooth Version | 5.0 |
Supported Bluetooth protocols | LDAC, aptX, aptX LL, aptX HD, AAC, SBC |
THD+N | DAC (XLR) : 0.0001% Amplifier (Jack 6.35mm headphone output) : 0.0004% Amplifier (Balanced output) : 0.0004% |
SNR | DAC (XLR) : 126dB Amplifier (Balanced output) : 123dB |
Housing material | Aluminium |
Dimensions | 22.2 x 17.8 x 4.5cm |
Color | Black |
Package | 1x DX7 PRO Black 1x Schuko power cable 1x Remote 1x USB-A to USB-B cable 1x Bluetooth antenna 1x Jack 3.5mm to Jack 6.35mm adapter |
Input | Bluetooth |
Input | SPDIF |
Input | I2S |
Input | XLR |
Input | Optical |
Output | XLR |
Output | Jack 6.35mm |
Output | RCA |
Output | Coaxial SPDIF |
Output | Jack 4.4mm |
DAC / ADC Chip | ES9038PRO |
Max sampling rate | 768kHz |
Max sampling rate | DSD1024 |
Color | Black |
Networking | No |
Remote Control | No |
Refurbished Grade | Grade A |
