IAN CANADA LINEARPI MKII DUAL Ultra-Low Noise Linear Power Supply Module 2x +/-12V +/-5V +/-3.3V 2.5A
The Ian Canada Linear Pi MKII Dual is an ultra low noise power supply module delivering high quality, high current, versatile and scalable. It is one of the best linear power supplies for Raspberry Pi or any other digital audio application.
Reference : 17612
139,00 €tax incl.
115,83 € tax excl.
Ian Canada LinearPi MKII Dual
The Ian Canada Linear Pi MKII Dual is an ultra low noise power supply module delivering high quality, high current, versatile and scalable. It is one of the best linear power supplies for Raspberry Pi or any other digital audio application. Several LinearPi modules can be combined to create a larger power supply system. This module can also be easily upgraded to a supercapacitor power supply by combining it with the IanCanada UcConditioner.
Points clés :
  • Linear power supply 2x +/-5VDC, +/-3.3VDC or +/-12V 2.5A
  • Ultra low noise level 0.8µV
  • Ultra low output impedance
  • High-speed, high-current, low-noise Schottky rectifiers with optional shunt capacitors
  • Integrated ON/OFF control logic with on-board or external ON/OFF switch
  • Multiple LinearPi's can be grouped together to create a complete power system, using the isolated master/slave control signal chain
  • Quick and easy upgrade to a supercapacitor power supply with the UcConditioner module (sold separately)
  • Continuous AC input mode for the best possible sound quality
  • Optional Kelvin sensor input for better performance
  • Deals with the piezoelectric noise of the MLCC
  • PCB with 2 ounce double layer copper circuitry for ultra low ESR
  • Input  6-9-12V AC or 9-12-15V DC
  • Robust SMT design
The improvements of the LINEAR PI version MKII
  • 5V, 3.3V and 12V configuration pure linear DC power supply, 2.5A rated output current
  • Two stages ultra-low noise soft start feature great for both digital and analog application
  • Total 13,200uF enhanced high capacitance high current ultra-low ESR filtering network for a significant improvement
  • Standard 5*20mm high performance glass fuse
  • Bigger and stronger ON/OFF switch
Product typeLinear power supply module
Output voltage2x +/-12v DC
2x +/-5V DC
2x+/-3.3V DC
Output current2.5A
Noise0.8µV
Input voltage3.3V configuration: AC6V or DC9V
5V configuration: AC9V or DC12V
12V configuration: AC12V or DC15V
Dimensions132 x 55.5mm
Mouting holes spacing115.5 x 48.5mm
InputScrew terminals
OutputScrew terminals
Output voltage (V)5.0
Output voltage (V)3.0
Output voltage (V)12.0
Output current (A)2.5
Input voltage (V)9.0
Input voltage (V)6.0
Input voltage (V)12.0
Power SupplyLinear
10 e lode
Una ovzaione per questo prodotto.
Ho provato e dupgradato molte alimentazioni lineari, ma questa le batte tutte.
Non importa cosa gli diamo in pasto e dove lo poniamo, da il suo contributo sempre e comunque. Il servizio Ian Canada è ottimo e l'assistenza pure.
Li uso uniti agli ultracondensatori venduti sempre da audiophonics. Sia su dac RMA adi 2 liscio e pro, sched eusb audio, router, switch. Le collego ad alimentatori lineari da 5mv per portare il segnale a ripple a 0,8uV. 5mV sono ben 5000uV (questa è l'unita di misura).
Indifferentemente se uso un triplo lt3045 con 0.8uV di altre marche che costano anche tre volte tanto (in autocostrzione) Ian canada linerapi mkII da i risultati migliori.
Inutile pensare molto, prendete un alimentatore lineare e fat convertire il tutto a IAN canada linerpi mkII ed avrete il riultato sperato, anzi, sopra le vostre aspettative. Ho fatto molte prove, trasformatori, alimentatori lineari costosi, medi, da telefoia. Ian canada porta il sengale dove ha deciso.
Ecco che ora uso un alimentator elineare da 45ampere sui 15V per il mio pc auio video gaming, prendo i 15 volt da questo super alimentatore (dato per ripple 5mV sui 45 ampere massimi) li converto in 12 volt grazie a ian canada, passo per gli ultracondensatori audiophonics ed entro nel dac.
Prendo dal mio convertitore DC atx a(limentato in lineare dai 45ampere sui 15 volt) la usa uscita rail lineare di 12V e 5mV ripple massimo ed entro in ian canada linearpi mkII e pacco ultacondensaotri ed entro nella scheda usb audio del pc.
10 e lode.
Uso ovunque ian canada linerpi mk II.
Cestinato gli altri alimentaori lineaei anche da 1000 euro.
E' una autocostruzione, ma vale la pena. Per cambiere l'uscita dai 12 ai 5 volt i ponticelli posteriori vanno dissaldati con stagntore. Non da tutti ma fi fa.
Per erogare i 12 volt va benissimo anch un alimentatore lineare d 13,8 di stampo telefonico.
This review has been posted for IAN CANADA LINEARPI MKII DUAL Ultra-Low Noise Linear Power Supply Module 2x +/-12V +/-5V +/-3.3V 2.5A
The Ian Canada Linear Pi MKII Dual is an ultra low noise power supply module delivering high quality, high current, versatile and...
