MUNDORF MRESIST SUPREME MRES20-3.3 Resistor 20W 3.3 Ohm
Resistor MResist Supreme 20W 3.3 Ohm
The Mundorf MResist SUPREME resistance range offers products of exceptional quality. Having a real impact on the sound restitution, these resistances allow to obtain finer details and a much better spatialization.
Reference : 4069
13,90 €tax incl.
11,58 € tax excl.
Shipping date: 26-04-2024.
Shipping from France
Billing in France
Technical support in France
Mundorf MResist SUPREME MRES20-3.3
Mundorf resistor MRES20-3.3
The Mundorf MResist SUPREME resistance range offers products of exceptional quality. Having a real impact on the sound restitution. This type of resistance allow finer details and a much better spatialization.
The structure of this resistance is composed of two wires 1Ω wound around a heat-resistant cement, this design stabilizes the inductance and maintains its value under 75µH.
Moreover, the resistors of the MResist SUPREME range are very useful for electronic systems designed for a deep neutrality in the sound reproduction. Thanks to a fire-resistant special molding compound, the resistance winding is stable and maintained in its optimal position, thus preventing the circuit from microphonic effects.
Finally, to guarantee a high quality sound even with heavy loads, a special Copper/Nickel alloy is applied as conductor with a positive and extremely low temperature coefficient of 50ppm/°C.
Resistance3.3 ±2%
Power20W
Body dimensions of the resistance51 x ⌀ 14.4mm
Wires dimensions40 x ⌀ 1mm
Resistance (Ohm)3.3
Tolerance (%)2.0
Power (W)20.0
Résistance utilisée dans projet CONFLUENCE cantilène répliqua, comparée à d'autres modèles ( mox, céramique...) l’aiguë se montre d'une finesse inouïe , lisse et précis dans le haut du spectre, fait preuve de matière et chaleur dans le haut médium en étant associée à un condensateur MCap Suprême...le résultat est merveilleux et justifie le prix de la résistance! REMARQUABLE.
This review has been posted for MUNDORF MRESIST SUPREME MRES20-3.3 Resistor 20W 3.3 Ohm
The Mundorf MResist SUPREME resistance range offers products of exceptional quality. Having a real impact on the sound restitution, these...
