FURUTECH FI-E30 NCF (R) Power Plug Schuko Type F Rhodium Plated Pure Copper
FURUTECH FI-E30 NCF (R) Schuko inlet Rhodium plated (Alpha)
Reference : 11336
57,90 €tax incl.
48,25 € tax excl.
Shipping date: 29-03-2024.
Shipping from France
Billing in France
Technical support in France
furutech-fi-e30-ncf-r-embase-schuko-cuiv
FURUTECH FI-E30 NCF
The base Schuko NCF FI-E30 (R) has several recent revolutionary technology developed by FURUTECH expert and global leader of the "Pure Drive".
After long sessions of plays and readings by audiophiles figures of Japanese industry, selected insulation materials are glass fiber and nylon recognized for their insulating properties.
Incorporated into select Furutech products, Nano Crystal² Formula --- NCF is comprised of a special crystalline material that has two “active” properties. First, it generates negative ions that eliminate static and secondly, it converts thermal energy into far-infrared. Furutech then combines this remarkable crystalline material with nano-sized ceramic particles and carbon powder for their additional “Piezo Effect” damping properties.
The resulting Nano Crystal² Formula is the ultimate electrical and mechanical damping material – only found in Furutech products !
Dimensions and distances
All dimensions are given in millimeters (mm).
conductorsα (Alpha) Pure copper Rhodium plated
Dimensions50.6mm × 50.6mm × 36.0mm ( L×W×H )
Insulation materialsNylon/fiberglass incorporating special “NCF” anti-resonance damping material - nano-sized crystalline, piezo ceramic particles and carbon powder
NCF Treatyceramic particles and nanoscale carbon powder for their "Piezo Effect" (cushioning properties)
Type2-pole +earth
Rating16A 250V A.C
Max cable diameter (mm)2.5
Mounting typeTo screw
ConnecticFemale
ConnectorSchuko
Rated current (A)16.0
8 reviews
Awesome Socket
I have tested this socket against few others and can say it's worth every penny and then some.
Sound with it is precise and 3D, but very natural and not too sharp or too bright at all.
Just needs 300h to break in properly, it will sound nasty at moments before that happens.
This review has been posted for FURUTECH FI-E30 NCF (R) Power Plug Schuko Type F Rhodium Plated Pure Copper
Apport non négligeable
Venu en remplacement des embases d’un filtre Torus à base d’un transfo d’isolement, j’ai été surpris de l’apport qui n’était pas que là où je l’attendais. En effet si le son est devenu plus ferme, c’est surtout au niveau des médiums et des aiguës que l’apport a été le plus spectaculaire. Un grand voile dont je n’avais pas conscience alors, a disparu et les aiguës ce sont révélés avec plus de finesse et de réalisme.
Je ne m’attendais pas à autant d’apport.
Jm,
Très satisfait
Franchement ca me semblait cher pour une simple embase ! J’ai longuement hésité.
Pour voir dans un premier temps , je n’en ai pris qu’une seule pour alimenter ma source ( Grandinote Volta). Je l’ai installée sur un inakustik ac-35000p . Il est doté de 6 prises mais qui n’ont rien à voir avec la qualité de fabrication et le rendu sonore de la furutech NFC.
Une fois installé, la différence se fait tout de suite entendre . Je rejoins les différents avis déjà cités . Tout est plus défini, je ne regrette vraiment pas cet upgrade.
Il ne me reste plus qu’à en commander deux autres pour mon Grandinote Supremo ! .
Prise NCF extra
Je l'ai montée en prise murale et sur 2 barrettes multiprises, gain sur beaucoup de paramètres d'où le relief amélioré.
pour l'adaptation en prise murale: j'ai adapté un modèle à 4€ à cache circulaire car mes murs en béton ont des encastrements de profondeur limitée : (
je ne sais pas si la prise murale Furutech à 3 fois le prix de celle-ci est meilleure, mais je suis Ok avec mon adaptation.
Impressionnant !
L'apport de cette prise secteur est très sensible, elle améliore la qualité du son (et aussi de l'image) à tous les niveaux, c'est impressionnant.
- Scène sonore élargie avec une bien meilleure localisation tridimensionnelle et stéréo des sons / voix / instruments.
- Détourage précis des différents registres.
- Timbres riches et nuancés, subtils et réalistes.
- Dynamique accrue, relief, grain.
- Basses plus propres et nettes, mais pas sèches : elle gagnent aussi en rondeur et en richesse.
- Beaucoup de détails sans que ça devienne artificiel ou envahissant : ça reste naturel et au service de l'expression, de l'émotion.
Sur mon système, le placage rhodium de cette prise me convient très bien : pas de dureté ni de brillance.
Avec cette schuko, on prend conscience de tous les détails que les micros sont capables d'enregistrer !
Si vous voulez faire progresser votre système, cette FI-E30 pourra vous surprendre, et même vous scotcher !
Je l'ai fixée sur une planche de chêne, elle-même fixée au mur ; elle remplace donc une prise murale.
J'y ai branché ma multiprise audiophile (d'entrée de gamme mais bien câblée par mes soins) et déjà l'apport est flagrant ! Alors qu'est-ce que ça serait sur une multiprise hdg...
Du coup j'en ai commandé une autre pour y brancher directement le smsl AD 18 (qui semble très sensible à la qualité de l'alimentation).
La télé (branchée avec un bon câble optique sur l'ad18) y gagne aussi beaucoup.
Par exemple sur des documentaires naturalistes, la prise de son, la voix off et la musique sont bien détachées les unes des autres, et c'est vraiment agréable, car très naturel et immersif.
L'image est aussi plus belle à tous points de vue (surtout avec un bon câble d'antenne), particulièrement sur les contrastes, le relief et les couleurs.
Cette prise semble chère, mais son tarif s'oublie dès la première écoute.
Je ne pensais pas qu'elle pourrait m'apporter autant.
Très bonne surprise, je suis ravi.
 (3)
