FURUTECH FT-SDS (G) Wall Plated Schuko Gold Plated
Furutech FT-SDS-G SCHUKO Wall plate
Reference : 2935
43,33 €tax excl.
Furutech wall socket with pure gold plated contacts.
Body in Nylon / Fiberglass.
Characteristics :
  • α (Alpha) Pure Copper Conductor Hand (t: 0.5mm)
  • Material: Nylon / fiberglass body and Polycarbonate cover
  • 1.0mm thick Zinc / steel brace plate Base Bracket
  • Maximum cable diameter: 2.8mm or 5.5 Sq.mm/10AWG Max. (set screw)
  • Dimensions: 54.8mm (W) x 54.8mm (W) x 52.0mm (H)
  • Furutech's total attention to detail and build quality extends right down to a specially designed patent-pending pressure plate that increases the contact area of ​​the Alpha Conductors.
  • Recessed diameter: 55mm
  • External Depth: 35mm
  • Type: 2-poles + ground
  • Rating: 16A 250V AC
  • Hole spacing: 40 x 40 mm
  • Cutout for the passage of the bottom plate 50x50 mm
MaterialCopper
PlatingGold
ConnectionTo screw
ConnecticFemale
Colissimo - TNT - SoColissimo
