FURUTECH FT-SWS NCF (R) Wall Power Plug Schuko Type F Rhodium Plated
FURUTECH FT-SWS NCF plated Schuko Wall plate
By buying this product you get 63 loyalty points
Reference : 11308
219,00 €tax incl.
182,50 € tax excl.
Shipping date: 25-04-2024.
Shipping from France
Billing in France
Technical support in France
The wall outletFurutech FT-SWS-R NCFis a new version with a body using the technological advances of the brand (see NCF technology).
Following the recognized qualities of Furutech ceramic technical developments "Piezo Effect" with cushioning properties, here is a very high level wall outlet.
As with the other Japanese brand plugs, it receives the patented Alpha treatment which has made the reputation of Furutech.
The high quality of contact for this high-quality outlet is the essential accessory for Hifi High End systems requiring the utmost attention of implementation.
Moreover this plug is Rhodium plated for a high stability over time of the mechanical and electrical characteristics of this wall outlet Furutech.
It also has "claws" to be kept in a wall location.
Two other versions are available in Gold and Rhodium finish (without) NFC for a perfect adaptation to your High fidelity system:
Furutech FT-SWS-G (Gold version)
Furutech FT-SWS-R (version Rhodium)
NCF technology:
Incorporated in the new series of Furutech products, the NCF (Nano Crystal² Formula) consists of a special crystalline material that has two "active" properties.
TFirst, it generates negative ions that eliminate static electricity, but it also converts thermal energy into far infrared (LIR) whose wavelength varies from (50 μm to 5 mm).
Furutech combine then this remarkable material with nanometric ceramic particles and carbon powder for their "Piezo Effect" (damping properties).
The resulting Nano Crystal² (NCF) formula is the ultimate electric and mechanical damping material - (only available in Furutech products!).
Features:/ Strong>
  • Treated with the α (Alpha) Pure copper process (t: 0.5mm)
  • Insulating treatment Nylon Fiberglass incorporating the NCF anti-resonant Nano particle process "Crystaline PiezoEffect" Ceramic and carbon powder.
  • Carbon and Cast Fiber Finish Zn-Mg Alloy front
  • Maximum cable diameter: 2.8mm or 5.5 Sq.mm / 10AWG Max
Dimensions:
  • Recessed diameter: 55mm
  • Recessed Depth: 40mm
  • Dimensions: 95.0mm (W) x 95.0mm (W) x 48.0mm (H) H)
  • Bare weight: 320gr
  • Type: 2-poles + ground
  • Rating: 16A 250V AC
Max cable diameter (mm)2.8
Mounting typeTo screw
ConnecticFemale
ConnectorType F (CEE 7/3 - CEE 7/4)
Rated current (A)16.0
7 reviews
Top qualité
Qualité vraiment au top pour ce bloc prise!
Rien que le poids en dit long!
Livré dans un petit coffret.
Gain significatif sur la propreté du signal! Un upgrade indispensable !
This review has been posted for FURUTECH FT-SWS NCF (R) Wall Power Plug Schuko Type F Rhodium Plated
Passage obligatoire !
Bonjour à tous, je confirme les avis laissés par les autres utilisateurs de cette prise Furutech NCF.
Voici mes impressions après quelques écoutes :
•Dureté du son⬇️
•Profondeur du Sound Stage ⬆️ ⬆️
•Réalisme et textures ⬆️⬆️
•Timbres des voix et instruments acoustiques ⬆️
•3D ⬆️
C'est plus fluide, "libéré".
La scène sonore se matérialise de façon naturelle.
Il y a un voile qui disparaît et une crispation en moins.
Ça peut paraître fou.
Mais chez moi c’est le cas.
Je précise que je suis équipé d’une multiprise non filtrée et qualitative, de câbles secteur de très bonne qualité, ainsi que d’une alimentation linéaire pour mon Dac, avec un SR Orange. ????
C’est ce qui a rendu l’amélioration aussi probante, cela ouvre une porte à un niveau encore supérieur.
Pour finir, je dirais qu’il s’agit d’une "Upgrade" incontournable de tout bon système audio/ vidéo.
Merci Audiophonics ????????????
Excellent
Je n'y croyais qu'à moitié, je rejoins l'avis de Christophe V. beaucoup de gain sur la transparence et le détail.
Déjà le serrage des câbles est meilleur que sur mon ancienne prise murale bas de gamme, cela peut expliquer en partie. Le produit est quand même cher, il complète très bien mon installation pour la qualité du rendu. Je gagne beaucoup en capacité dynamique, sur les voix, sur des phénomènes de crispation dans l'aigu un peu présents sur les pointes de dynamique auparavant. Sur pas mal d'albums, j'entends des détails qui m'étaient inconnus jusqu'à présent.
Le montage de la prise est assez facile.
Une Tuerie!
Pour avoir eu l’ancienne prise version rhodium sans le traitement NCF pendant plusieurs années, j’ai décidé de passer sur cette version NCF qui je dois dire l’enterre littéralement sur les points de référence telle que la finesse,la clarté sur les voix font un bon en avant de façon considérable, écoute beaucoup plus naturel sans aucune sensation de coloration qui pouvait être un peu la critique de l’ancienne version...
Le grave est plus détouré avec une belle extension sans caricature.
Petit conseil, tout amélioration d’un système haute fidélité devrait déjà commencer par cette prise avant de toucher à autre chose
Une référence !!
Vaut vraiment la peine
Ce qui étonne en premier lieu avant le montage, c’est le poids conséquent de la prise et la qualité de fabrication.
A l’écoute bien que non rôdé la différence saute aux oreilles, le son est plus tendu, on se retrouve un peu plus près des instrumentistes, l’acoustique de la pièce dans laquelle a été fait l’enregistrement des morceaux se fait ressentir faisant ainsi s'effacer les enceintes.
Je reste toujours surpris de constater combien le traitement du courant influe grandement sur la restitution sonore. Mais en y réfléchissant cela est logique car il y a un aspect cumulatif puisque tous les appareils en bénéficient et ainsi aussi tous les câbles audio, bref chaque maillon du système est impacté.
Jm,
 (3)
