White SPI / IIC 256x64 OLED 3.12" screen
EarMen Donad DAC CS43198 32bit USB XMOS PCM 384kHz DXD MQA
Here is a very elegant 3.12 "256x64 OLED screen with superb brightness and excellent readability. It is already mounted on its PCB with a soldered connector.
4.0 / 5
Reference : 14604
29,90 €tax incl.
24,92 € tax excl.
Shipping date: 26-04-2024.
Shipping from France
Billing in France
Technical support in France
OLED Display 3.12" 256x64
Here is a very elegant 3.12 "256x64 OLED screen with superb brightness and excellent readability. It is already mounted on its PCB with a through pads.
This screen model is used in our SABRE EVO DAC & network streamer where it serves as a secondary screen connected directly to a Raspberry Pi 4.
Example of use
This screen model is used in our SABRE EVO DAC / network player where it serves as a secondary screen connected directly to a Raspberry Pi 4.
Connector already mounted
This version of the screen is configured with a 4-SPI interface output. The connector (2x8 pins) is already mounted on the circuit to allow you to use the screen immediately and without having to solder the component yourself.
Écran OLED 3.12 SPI / IIC 256x64 Blanc
TypePCB mounted screen with pre-soldered PIN
Resolution256*64
Dimensions100.5 x 33.5 x 6.3 mm
Display area78.8 x 21.18 mm
Protocole / driverSSD1322 / EQV
Port8-bit interface 6800/8080 parallel port 3/4 SPI
ColorWhite
Tension3.3V
Configuration interface 4-SPI
PinSymboleNiveauFunction
1GND0VPower Ground
2VDD3.3 ... +5.0VPower Supply
3NC-No connect
4SCLK (D0)H/LSerial CLock Signal
5SDIN (D1)H/LSerial Data Input SIgnal
6NC-No connect
7-13NC-No connect ( or power ground)
14D/C(RS)H/LH : Data
L : Command
15/RSTH/LActive LOW : reset Signal
16/CSLChip Select
2 reviews
Top quality, great display
Great display, after some hours of struggling (I'm a beginner) I managed to drive this display with my NodeMCU microcontroller, from Arduino IDE, using the u8g2 graphics library. Amazing, it's using the fast mode (hardware SPI), with 3 wires only (4 is optional) + GND + 3v3.
You can see the library's example here, doing a demo:
https://www.youtube.com/watch?v=VX7gFL9v1qo
Amazing little display and very nice, refined screen. Top quality.
Please Audiophonics, keep this on stock, a lot of them, as long as you can. Really easy to work with.
Highly recommended.
This review has been posted for White SPI / IIC 256x64 OLED 3.12" screen
My review on the White SPI display
Nice display, once I got it to work. if you use this display with an RPI4 equipped with Volumio or Roon or LMS it is probably a breeze to get it to work. Plug and play. One thing to look out for is the 16 pins flatcable connector that can be fitted in two ways on the display. The cable keying (triangle indicating pin 1 on the connector) should be connected to pin 15 of the display. something to look out for.
I tested the display using the python luma driver with the following test code:
from luma.core.interface.serial import spi
from luma.core.render import canvas
from luma.oled.device import ssd1306, ssd1322,ssd1325, sh1106
from time import sleep
import RPi.GPIO as GPIO
serial = spi(device=0,port=0,gpio_DC=27,gpio_RST=24)
device = ssd1322(serial, rotate=0)
# Box and text rendered in portrait mode
with canvas(device) as draw:
draw.rectangle(device.bounding_box, outline="white", fill="black")
draw.text((10, 10), "Hello World", fill="white")
sleep(10)
The GPIO pins mentioned in the code above were determined after measuring the pins from CN4 all the way to the Pi pins.
An improvement would be to add a column to the display specs on the website indicating what PI pins are used. Now I had to measure them myselve.
Here is a very elegant 3.12 "256x64 OLED screen with superb brightness and excellent readability. It is already mounted on its PCB with...
