AUNE X7S Headphone Class A amplifier Variable Out Balanced Black
Aune X7S Headphone Class A amplifier Balanced Out black
The pure class A Aune X7S headphone amplifier with balanced output is the result of a long search after the nomadic headphone amplifier Aune B1 and the Aune Panda. It is the natural companion of the DAC Aune X1S 32bit 384Khz DSD SABRE ES9018K2M. This headphone amp entirely in class A is the synthesis of all the know-how of Aune Audio.
4.8 / 5
Reference : 10953
249,00 €tax incl.
207,50 € tax excl.
Shipping from France
Billing in France
Technical support in France
Aune X7S
Headphone amplifier Class A Variable output / Balanced Black
Aune X7S Amplificateur Casque Class A Sortie Variable / Symétrique Noir
The pure class A Aune X7S headphone amplifier with balanced output is the result of a long search after the nomadic headphone amplifier Aune B1 and the Aune Panda. It is the natural companion of the DAC Aune X1S 32bit 384Khz DSD SABRE ES9018K2M. This headphone amp entirely in class A is the synthesis of all the know-how of Aune Audio. It is specially designed for high-end high impedance headphones such as: Sennheiser HD650, IE800, HD800, Beyerdynamic (Tesla) T1, DT880, AKG K701, K240.
Its gain stage, which can be configured by "switch", allows a perfect impedance matching for both low and high impedance headphones. Its structure is based on 8 Class A polarized transistors divided into 4 groups designed with a true symmetrical stage for cross talk and remote, inaudible background noise. The European sound of the Aune X7S developed by an English team has body, a deep sound image with increased natural musical tracking, a true sound signature of headphones amplifiers in class A. The separate 15 V regulated low noise power supply provides the stability necessary for the Aune X7S to operate properly in class A. By its unique design the Aune X7S will be an ideal companion for the dematerialized digital player Aune X5.
Review and measurements by Audio Science Review
The Audio Science Review forum offers a particularly complete test of the Aune X7s with in particular precise measurements of the different parameters of the device.
ClassA
Frequency response20Hz-200kHz @ -0.3dB
Noise level3µV
THD0.00013%
Inter-modulation distortion (CCIF protocol)RCA : 0.000036%
XLR 0.00057%
Output powerRCA : 250mW @ 300 Ohm / 1000mW @ 32 Ohm
XLR : 1000mW @ 300 Ohm / 1700mW @ 32 Ohm
SNRJack 6.35mm : 117dB
XLR : 125dB
Input1x Stereo RCA
Outputs1x Variable Stereo RCA
1x Jack 6.35mm
1x XLR 4 poles balanced
Dimensions145 x 171 x 45mm
Weight2kg
OutputJack 6.35mm
4 reviews
Très bon produit, excellent rapport qualité/prix
Il est rare que je poste un avis, néanmoins, quand le service et le produit est de qualité, il est important de le notifier.
Tout d'abord je tiens à préciser que la gestion/envoie de ma commande a été très rapide, bien emballer etc, rien à redire.
Tout d'abord, je tiens à précisé que j'ai associé cet amplificateur avec mon RME ADI-2 Dac, et que mon avis est purement subjectif !
Les casques utilisés : Audeze LCD-X, AKG K712 pro, B&O H7, DT 770 pro 250 Ohms.
Médias players utilisés : foobar2000 et Tidal.
Cet ampli rempli parfaitement sa fonction principale, il a suffisamment de puissance, même pour des casques gourmands (comme le K712), il ne pourra surement pas alimenté certains casques électrostatiques, mais je pense qu'il peut alimenter sans soucis 95% des matériels !
Autre fonction, la mesure, en effet cet ampli mesure extrêmement bien, ce qui est plutôt surprenant pour un produit à 250 euros, ce qui montre la qualité de certains produits de moins en moins onéreux (THX 789, THX 888, mais aussi celui-ci). En effet, cet ampli rend mon son très juste, avec des aigus mis en avant, ce que j'aime bien, c'est un régale pour les "females vocals", (fuyez si vous n'aimez pas les aigus légèrement présents) cependant le reste n'est pas en deçà, les graves et les médiums sont présentes malgré un petit manque de pep's dans les bas médiums, mais il ne faut pas oublier que ce produit ne coute que 250 euros.
Par ailleurs, ce produit est doté d'une bonne dynamique, loin d'être transcendant, mais très agréable qui conviendra je pense à la plupart des futurs acquéreurs.
Outre ces performances, c'est un produit sobre, très bien fini, une vraie brique très lourde et solide avec un très bon "knob", ce qui est appréciable, ainsi que tous les ports nécessaires pour une grande majorité des installations.
J'ai cependant 3 problèmes avec cet ampli, mineurs certes mais ils existent :
- Le fait que le switch on/off soit au dos de l'appareil, qui n'est à mon sens pas du tout pratique.
- Le transformateur qui est vraiment gros, donc pas évident pour le câble management, pour ceux qui se posent la question, il passe (difficilement) dans un Ikea signum rak.
- Le manque de Hi/low gain switch.
En somme, un excellent amplificateur, avec des défauts mineurs, c'est pour ça que je ne met pas 5 étoiles à ce matériel, néanmoins, vous pouvez foncer les yeux fermés parce que je vous garantie que vous allez aimer cet ampli qui pourra alimenter vos casques sans soucis, et qui tiendra sûrement un bon moment !
This review has been posted for AUNE X7S Headphone Class A amplifier Variable Out Balanced Black
Excellent ampli casque
J'utilise cet ampli avec un casque Seenheiser HD650 et un HD599
Après avoir testé les 2 casques avec un gain de 20db j 'ai trouvé le réglage du volume n'était pas assez progressif avec le hd650 et pas du tout avec le hd599 ( concernant le hd599 50 ohm il fallait s'y attendre ).
Je suis donc passé à un gain de 12db et là la progressivité des réglages de volume sur les 2 casque s'est nettement améliorée et ce niveau de gain alimente très bien de HD650.
L'image stéréo aussi bien en largeur qu'en profondeur est assez impressionnante, les attaques de l'orchestre sont franches et les instruments très présents.
Je suis aussi très satisfait du service d'AUDIOPHONICS.
Ampli casque et préampli X7s Aune
Je cherchais un ampli casque et un préampli pour mon système Hi-fi de qualité Hi Res.
Achat en aveugle car je n’ai pas trouvé de review pertinente sur ce X7s cependant il est en class A (espoir)
Je l’utilise en couple avec l’Aune X5s et l’alimention spécifique XP1 d’Aune sur laquelle il est possible de connecté les 2 appareils.
Partie casque, j’ai testé avec mon Sennheiser HD 25 C en jack, l’écoute est superbe bien au-dessus de toutes les possibilités des différents matériels émetteur que j’ai en ma disposition, préampli, S8+ ,PC , lecteur CD.
Image, stéréo, timbre avec beaucoup de chaleur et une sensation de puissance illimité, bien au-delà du supportable.
Test avec mon Sennheiser HD 650 en mode Jack, l’écoute est également superbe avec en plus des détails dans le grave et l’infra. Je le trouve du coup un peu trop chaleureux, mais très agréable. Puissance énorme et largement suffisante
Je branche mon cordon symétrique en XLR 4 pôles sur le HD 650. Alors là, je suis dans un autre monde. Une dynamique terrible, un spectre audible très large, cette chaleur excessive gênante moins importante remplacé par des nuances et timbre de grave jamais entendu, vraiment les peaux des instruments est très « lisible » avec fidélité. Je change la SD de mon X5s pour passer des morceaux en 48/24 et 96/24 de Qobus. Et là le bonheur, Je crois que c’est ça de la Hi Res, Ouah des détails, de la stéréo, du timbre incroyable, une image large et profonde, un aigu très détaillé et doux. Je cherche des morceaux très bien enregistré de grande musique avec orchestre pour vérifier le placement dans l’image ; c’est tout simplement génial. Restitution du positionnement des groupes d’instruments dans l’orchestre. Pour moi c’est une découverte.
En mode préampli c’est également tout nouveau, le X7s branché sur mon ampli Grand Mos j’obtiens une image superbe large, profonde. Je redécouvre mes enceintes Davis et la qualité des HP et leur dynamisme. Je continu à tester le positionnement de l’orchestre. Je suis épaté par le grain des violoncelles …. « Cela prend aux tripes »
Le couple X5S + X7S avec le XP1 soit sur casque ou en chainon dans un système Hi-Fi en Hi-Res haute définition ressemble aux écoutes vinyle master de ma jeunesse dans les salons Hi-Fi. Je valide mon achat et je vais passer de grande bonne heure de plaisir.
Une tres belle construction ! J'ai testé également le cable entre les 2 chainons Aune il faut une bonne qualité.
Ampli exceptionnel même en asymétrique !
Utilisé en ensemble avec mon Aune X1S.
Je pense que cet ampli n'a pas l'attention qu'il mérite. La scène sonore est large et profonde, l'ensemble du spectre est respecté. Une toute petite pointe de chaleur qui contrebalance bien le côté légèrement brillant de mon X1S en Sabre. Le combo avec le X1S est gagnant sur tout les plans. Puissance, neutralité et transparence, cet ensemble fait pour moi référence avec mon AKG K712 Pro!
Je précise que je n'ai pas utilisé la sortie casque symétriques, qui, d'après les essais va encore plus loin.
Je n'ai à aucun moment eu le besoin d'utiliser le mode High Gain, je n'ose imaginer la puissance en symétrique et en HG, je ne vois aucun casque qu'il ne serai pas capable de driver !
The pure class A Aune X7S headphone amplifier with balanced output is the result of a long search after the nomadic headphone amplifier Aune B1 and...
