LITTLE DOT MKIII MK3 Headphone Tube Amplifier
Little Dot MKIII MK3 Amplificateur casque à tubes
The Little Dot MKIII is a very nice tube headphone amplifier, offering excellent audio performance. It is topped by two GE5654 tubes (United States GE) for its input circuit and two 6H6 tubes (Russia) for its output circuit.
Reference : 3441
299,00 €tax incl.
249,17 € tax excl.
Little Dot MKIII
Tubes Headphone Amplifier
Little Dot MKIII Amplificateur casque à tubes
The Little Dot MKIII is a very nice tube headphone amplifier, offering excellent audio performance. It is topped by two GE5654 tubes (United States GE) for its input circuit and two 6H6 tubes (Russia) for its output circuit. Its meticulous internal design allows it to provide comfortable power to accompany many headphones, while revealing a beautiful soft and round signature, without neglecting precision. The components are integrated in a robust aluminium housing.
Underneath the device are settings to change the gain and the type of tubes that can be used. The table below shows the different possible settings.
Note: Make sure that the unit is not powered when making a change to any of these settings.
Gain setting
By default, the amplifier is delivered with a gain set to 3. Two DIP switches are used to adjust the amplifier gain:
Switch : Position 1Switch : Position 2GainHeadphone type
OFFOFF10High impedance headphone (>= 300 Ohm)
ONOFF5Medium Impedance / Sensitivity
OFFON4Medium Impedance / Sensitivity
ONON3High sensitivity
Tubes type setting
Two jumper under the unit allow you to change the type of tubes that can be used with it. Two possibilities:
  • If the contacts are not connected (no jumper), the following and equivalent tubes can be used: WE301A/B, GE5654, M8100, CV4010, EF95, 6J1, etc.
  • If the contacts are connected (jumper in place), the following and equivalent tubes can be used : EF92, EF91, CV138, CV131, etc.
Note: By default the amplifier is set to the first option.
Product typeTubes headphone amplifier
TubesInput : 2x GE5654 (United States GE)
Output : 6H6 (Russia)
Input1x Stereo RCA
Output1x Stereo RCA SEPP (Single-Ended Push Pull) Class A
Distortion0.15% @ 300 Ohm 80mW
Output power350mW @ 600-300 Ohm
300mW @ 120mW
100mW @ 32 Ohm
Variable gain3x, 4x, 5x ou 10x
Input impedance (4 tubes used)Output impedance: 600 Ohm
Gain : 3-10x adjustable via DIP switch
Voltage : 10Vrms
Consumption30W
Case materialAluminium
Dimensions175 x 270 x 123mm
Weight3kg
ColorSilver panel, Black body
Package1x Little Dot MKIII
1x RCA Cable
1x Jack 3.5mm to 6.35mm adapter
1x Power cable
1x User Manual (EN)
OutputJack 6.35mm
Channel2 channels (Stereo)
Colissimo - TNT - SoColissimo
4 reviews
un Ampli casque à Tubes exception
J'ai acheté récemment cet ampli à tube pour un Sennheiser HD 700 - avec un réglage de gain "5" - cet ampli permet une restitution sonore optimum idéale pour écouter de la musique classique pendant des heures et des heures sans fatigue auditive ( comme avec un ampli à transistor basique donnant des aigus souvent trop agressifs ) avec une précision dans tous les détails de l'enregistrement -
Sur le pop rock et toute autre forme de musique moderne , il donne un son doux et une scène sonore incroyablement riche tant dans l'aigu que dans le grave - mais il révélera aussi tous les éventuels défauts de la source car cet appareil est réellement un produit haute fidélité ...
un 10/10 pour ce produit et un grand merci à Audiophonics pour nous faire connaître cette marque Little Dot qui permet de rentrer dans le monde de la hi-fi à tubes sans se ruiner...
This review has been posted for LITTLE DOT MKIII MK3 Headphone Tube Amplifier
Little Dot MKIII
Il faut changer les 'tubes'! Voshkod 6ZH1P-EV. Shunts EF95. Electro Harmonix 6H30Pi. Et en suite rodage, rodage rodage! Apres ca un regal avec les ecouter Sennheiser HD600 etc.
Little Dot MKIII
A superb amplifier for the money. Change the pre-amp tubes to Voshkod 6ZH1P-EV and set the jumpers to cover pins 1 and 2 (EF95). Change the power tubes to Electro Harmonix 6H30Pi gold. Run-in for a very long time (1 week). Sounds excellent with HD600 Sennheiser headphones.
J'ai attendu quelques temps pour bien tester cet appareil avant de vous donner mon avis. Je l'utilise avec un Sennh HD-650 et un HD-595.
Tout d'abord, l'ampli lui-même est une belle pièce d'électronique. Qualité de fabrication excellente. Pour le prix je ne vois pas comment on pourrait faire mieux. Beaux matériaux, bien assemblés. Niveau fonctionnement, aucun bruit de fonds ni ronflette avec mon HD-650. Il est vraiment "black dead quiet" comme disent nos amis anglosaxons !
La possibilité d'adaptation manuel du gain par petits switchs accessibles sous l'ampli est un réel plus pour une bonne adaptation à tout type de casque.
Le son en lui-même, avec les tubes d'origine est un peu bruité, typé très doux, peu dynamique et un peu trop sage à mon goût pour le HD-650. Il doit être d'origine par contre très bien adapté à un AKG K-701 par exemple. Personnellement, j'y ai mis une nouvelle paire de tubes NOS anglais (EF92 HALTRON à 12€ la paire seulement) et là : la claque ! On garde le son tube, mais avec bien plus de détail et de dynamique. Les timbres sonnent à la perfection, sans agressivité mais très précis. Les basses sont soutenues, modulée et détaillées. les aigus pétillent avec précision, sans laisser-aller. le médium reste plein et suave, transparent.
En conclusion : excellent petit ampli qui en donne bien plus que son prix ne laisse présager, mais surtout très sensible au changement de tube ! En effet c'est un montage "pur tube" en classe A. Ce qui permet de choisir le type de restitution en fonction de ses goûts. Cet ampli mérite de bons tubes, n'hésitez pas !
The Little Dot MKIII is a very nice tube headphone amplifier, offering excellent audio performance. It is topped by two GE5654 tubes (United States...
