Little Dot MKIV MK4 SE Headphone Amplifier
Little Dot MKIV MK4 SE Amplificateur casque à tubes
By buying this product you get 64 loyalty points
Reference : 5439
649,00 €tax incl.
540,83 € tax excl.
Available
Shipping date: 24-09-2018.
Orders placed before 1pm (GMT+1) will be shipped the same day (working day).
Little Dot Headphone Amplifier MKIV MK4 SE
The Little Dot MKIV is the flagship headset amplifier of the brand.
It uses a Single Ended Push-Pull amplifier circuit class A based on MC8100 / CV4010 tubes.
These tubes are surrounded by quality components such as a potentiometer ALPS RK-27, capacitors Nichicon, Rubycon, WIMA, ERO ...
This amplifier can driver headphones from 32 to 600ohm without forcing thanks to its output capable of 45V peak-to-peak.
RCA outputs allow it to be used as a preamp by taking advantage of the Class A
In addition to this, this amp includes an externally accessible gain adjustment to best match the impedance of your headphones.
It is also possible to change the input tubes by EF92, CV131, WE403A / B, GE5654, M8100, CV4010, EF95, 6JI or compatible (Requires the addition of a jumper)
The versionMK4 SEis a special edition that features improved connectivity such as a Jack Neutrik socket, branded RCA sockets, and first choice components at key locations on the circuit.
The versionSEalso uses different tubes, M8100 / CV4010 input, and 6H30PI with golden pins as power tubes.
Specifications:
  • SEPP (Single Ended Push Pull) OTL in Class-A
  • Frequency response: 10Hz - 100kHz (-1dB)
  • THD + N: 0.1% (100mW @ 300 ohm)
  • Output Power
    • 500mW @ 300/600 ohm
    • 300mW @ 120 ohm
    • 100mW @ 32 ohm
  • Power Consumption: 30W
  • Adjustable gain: 3, 4, 5 or 10x
  • Recommended load: 32 to 600ohm
  • Input impedance: 50k ohm
  • Preamp section:
    • Output impedance: 600 ohm
    • Gain: 3 to 10x (linked to amp gain)
    • Voltage: 10V RMS
    • Input and output tubes active on output preamp
  • Input Tubes:
    • 2x JAN 5654 (MKIV)
    • 2x M8100 / CV4010 (MKIVSE)
  • Power Tubes:
    • 2x Soviet 6H30EH (MKIV)
    • 2x 6H30PI Gold-pin (MKIVSE)
  • Aluminum chassis
  • Dimensions: 320x220x143mm
  • Weight: 3.5kg
  • Warranty 1 year
  • Comes with a 6.3mm to 3.5mm jack adapter
Colissimo - TNT - SoColissimo
le Little Dot MK4 SE est superbe !!! finition exemplaire , le son est superbement chaud et détaillé, je l'ai depuis 3 jours et suis impatient de finir le rodage pour pouvoir profiter pleinement de sa restitution sonore qui je sais ,va s'améliorer avec le temps.......
je l'utilise aussi comme préampli un régal , je suis vraiment comblé par mon achat .
seule ombre au tableau je ne sors plus de chez moi , et reste scotché devant ma chaine , enchainant les disques !!!!!!
This review has been posted for Little Dot MKIV MK4 SE Headphone Amplifier
