SMSL VMV VA2 Headphone Amplifier Audiophile Analog
VMV Audio VA2 Amplificateur Casque Audiophile Analogique
The SMSL VMV VA2 is a high quality headphone amplifier and ideal companion for the Magic converter of the same brand. Capable, despite its small size, of driving the most demanding headsets on the market, it will be as comfortable behind a DAC as it is connected directly to an analog source.
Reference : 8555
129,00 €tax incl.
107,50 € tax excl.
Shipping from France
Billing in France
Technical support in France
SMSL VMV Audio VA2
SMSL VMV Audio VA2 Amplificateur Casque Audiophile Analogique
The SMSL VMV VA2 is a high quality headphone amplifier and ideal companion for the Magic converter of the same brand. Capable, despite its small size, of driving the most demanding headsets on the market, it will be as comfortable behind a DAC as it is connected directly to an analog source. It has two 6.35mm headphone outputs: one for high impedance headphones and the other for low impedance headphones. This allows it to be used universally, whether with in-ear earphones or 600Ω headsets.
SMSL VA2 Review byAudio Science Review
" So overall, a competent design from SMSL here and I can recommend it. "
Test du SMSL VA2 par Audio Science Review
Product typeHeadphone amplifier
Input1x Stereo RCA
Outputs2x Jack 6.35mm
THD+N< 0.0003% @ 1kHz, <0.0008% @ 20Hz-20kHz
SNR> 122dB
Crosstalk< 95dB-1kHz, <-75db 20hz-20khz="" td="">
High impedance output power> 120mW @ 600Ω, > 250mW @ 300Ω, > 580mW @ 100Ω, > 330mW @ 32Ω
Low impedance output power> 120mW @ 100Ω, > 75mW @ 32Ω
Case materialCNC machined Aluminium
ColorSilver
Power supply12VDC 1A via Jack DC 5.5/2.5mm (power adapter included)
Dimensions120 x 95 x 22mm
Weight0.5kg
OutputJack 6.35mm
ColorSilver
The SMSL VMV VA2 is a high quality headphone amplifier and ideal companion for the Magic converter of the same brand. Capable, despite its small...
