XDUOO TA-10 USB Tube Headphone Amplifier class A Hybrid
xDuoo TA-10 USB Tube Headphone Amplifier class A Hybrid
The xDuoo TA-10 is a tube and DAC amplifier for headphones, incorporating an XMOS USB chip. He will offer you a sound reproduction of the most just.
4.7 / 5
By buying this product you get 28 loyalty points
Reference : 12270
289,00 €tax incl.
240,83 € tax excl.
Shipping from France
Billing in France
Technical support in France
xDuoo TA10
DAC USB XMOS Headphone Amplifier
xDuoo TA10 Amplificateur Casque à Tube
This amplifier is a more upmarket evolution of the small xDuoo TA03 headphone amplifier. Equipped with a classic 12Au7 triode tube that is recognized for the quality of its timbre, this tube headphone amplifier with 32 bit DAC USB is capable of controlling a wide range of high-impedance (600Ohm) audiophile models with balanced 4 poles "Sennheiser". It brings the tube sound and class A transistors to many Hifi headphones such as AKG, Beyerdynamic, Sennheiser, Audeze, Audio Technica, Hifiman, Meze Audio.
A PCM and DSD USB DAC of quality
XMOS
the xDuoo TA10 produces a melodic sound for long hours of musical pleasure without auditory fatigue. Equipped with a DAC AKM AK4490 and a USB input XMOS U8 bit perfect it is also powerful for PCM DXD 32bit 384khz that for DSD64 / DSD256. It integrates two separate clocks for better precision according to the chosen sampling multiple of 44.1Khz (352.8Mhz MAX) or 48khz (384Khz MAX).
Compact and easy to use
The xDuoo TA10 features a multifunctional volume button to choose from the 2 line-in and USB inputs identifiable on the front panel. With an area equal to a sheet of A5 paper, the xDuoo TA 10 takes up little space on a desk and will therefore be the perfect companion for desktop Hifi systems and tight spaces but high quality.
xDuoo TA10
Tube AmplifierFor symmetrical headphones
TubeDriver 12AU 7 and Class A transistors
Integrated linear power supply230
Input selection and volumeWith multifunction button
screenIn front
Chassis MaterialCNC Machined Aluminum
Bandwidth10Hz to 100kHz +/- 1dB
Signal Noise Ratio115dB
Gain+ 18dB
Distortion by harmonic at 1kHz over 32Ω0.01%
Output power
Output power on Jack 6.352000mW on 32Ω
Output power on XLR Balanced 4 pins2000mW on 32Ω
Line inputs RCA and XLR
RCA inputsX2 line
Digital inputUSB 32bits 384kHz, DSD64 to DSD256
Headphone and line outputs
Stereo balanced 4-pin stereo headphone output on XLR balanced SennheiserFrom 8 to 600Ω
Stereo Headphone Jack 6.3mmGold Plated
Stereo analog auxiliary output fixed line
Coaxial Digital Output SPDIF
Miscellaneous
FoodInternal linear power supply AC100V 230V on IEC connector
Dimensions32 x 12 x 105mm
Weight1.50kg
Accessories1x xDuoo TA-10
1x Câble USB-A vers USB-B
1x Adaptateur Jack 3.5mm vers Jack 6.35mm
1x Power cable
1x CD Drivers
xDuoo TA10
OutputCoaxial SPDIF
10 reviews
Pas déçu !
Très bon ampli casque, surpris pour un prix "raisonnable"
les points forts :
- Bonne partie ampli, avec une petite modif à faire
- Finition sympa
- arrive à alimenter un hifiman sundara sans broncher(80% ça marche bien fort déjà)
-on peut changer la lampe facilement
- en mode auxiliaire cet ampli est énorme une fois réglé(changement lampe) !
ponts faible.:
-La partie DAC est pas mal, bon rendu dans l'ensemble , mais beaucoup de clac et de crac au démarrage et à l'arrêt de la musique. Ça doit pas arranger les casques !
- La lampe est clairement à changer par une electro harmonie gold. J'ai, trouvé pas mal de grésillements et un son un peu fade avec la lampe d' origine
Pour résumer c'est un très bon matériel une fois la lampe changé, la partie dac dépanne vraiment pour écouter direct sur un PC ou un smartphone avec un adaptateur OTG. ET si on veut une bête de course, branchement d'un dac externe( I Sabre par exemple) sur le canal auxiliaire et c'est du régale.
testé avec un casque hifiman Sundara avec soit un smartphone en mode OTG, un PC sur Linux/Ubuntu (reconnu direct) et un raspdac mini avec la sortie RCA
This review has been posted for XDUOO TA-10 USB Tube Headphone Amplifier class A Hybrid
xduoo ta-10
Après de longues heures d écoute,que dire sur ce produit .
Vraiment déçu!!!
Pas par le produit en lui même, mais par son prix.
Je m explique par la...
Dans ma région, plus de magasin de hifi, donc difficile de se faire une idée .
Je fais comme tout le monde, je regarde les commentaires ,sur les produits qui m intéressent .
J achète au pif en fonction des éloges, ça passe ou ça casse.
J ai pris contact avec ce site , en leur expliquant mes attentes.
Ils m'ont dit que le produit allait me convenir; c était un bon choix!
Badaboum ,un flop total, 299 euros mis a la poubelle.
J ai un Dac à 89 euros qui fait le même boulot .
J ai fait écouter à plusieurs personnes,nous sommes unanimes; pratiquement pas de différence lorsque on écoute de la musique.
Par contre, le xduoo ta-10 s'en sort moins bien que mon dac magic en écoute vocale .
Des " S" qui sifflent, très énervant.
En général je ne mets pas de commentaire , mais je suis trop déçu de ce produit .
Un très bon ampli / DAC
Ce petit DAC ne paye pas de mine, et pourtant….. Très belle finition et le son très très bon pour son tarif, mais n’oubliez pas de roder la bête!!! Sur un PC portable Windows, vous y verrez une grande différence! Moi, je suis en MAC et une fois rôdé, c’est le jour et la nuit.
Le gros défaut que je trouve rédhibitoire est le manque cruel de sorties en entrée tel qu’une prise toslink pour le brancher sur une télé multimédia ou une console de jeu. Si vous voulez le faire fonctionner sur une télé via Toslink, il vous faudra prendre un petit DAC sans volume avec câbles RCA et Toslink. Tout çà pour environ 50 euros sur le site d’Audiophonics.
Pour 300 euros, vous en avez quand même pour votre argent. Cela reste un produit très bien placé.
Complément avis précédent
Problème avec la Genalex, un souffle apparaît qui n'existait vraiment pas au départ! donc Florian R. avait sans doute raison...
Dommage j'aimais bien le son avec ce tube, mais ça n'enlève rien aux qualités du TA-10.
Je remonte l'Electro Harmonix Gold, pas de souffle.
Très sympa!
J'ai acheté le mien d'occasion, le vendeur l'avait pris chez Audiophonics.
Mon TA-10 est équipé d'une Electro Harmonix Gold qui va bien dessus.
J'essaye une Genalex Gold Lion achetée sur le site, et contrairement à l'avis de Florian R. je n'ai aucun problème de souffle, son exemplaire était peut-être défectueux?
Toujours est-il que je préfère la Genalex, c'est plus fin partout. Le grave en particulier très défini, rond comme j'aime mais pas trop. Médium détaillé et aéré, aigu fin et aucune agressivité. Je trouve le son plus "tube" avec la Genalex.
Le casque que j'utilise est un Fostex TH900.
Le dac à base d'AK4490 rien à dire, en tous cas le combo dans sa globalité est excellent. C'est meilleur avec un câble usb comme le modèle d'Audiophonics, ou le Neotech argent monobrin. J'ai essayé aussi avec une Regen alimentée par une Ifi Ipower 9v et deux câbles usb Neotech argent, ça exploite bien la liaison PC vers dac mais ça n'engage que moi.
